02-03-2008, 09:30 AM   #1 (permalink)
marvsfords
Smile tko going in 69 mach 1
anyone ever put a tko in a 69 or 70 mustang? Im trying to decide if I go with a hydraulic or
cable set up. Thanks.
marvsfords is offline   Reply With Quote
02-03-2008, 09:35 AM   #2 (permalink)
mustang4665
Re: tko going in 69 mach 1
Fortes(Forte's Parts Connection (508) 875-0016 - TREMEC DEALER, FACTORY FIVE COBRA PARTS, FORD RACING PARTS, FFR MKI and MKII, MUSTANG PARTS, TRANSMISSIONS, T-56, T-5, TKO, TR-3550) in Massachusetts and Keisler(Keisler Engineering, Inc. The best 5-speed and 6-speed transmission systems | Classic car transmission | camaro transmission | corvette transmission | mustang transmission) in Tennessee both sell a kit for early mustangs. I am using the keisler TKO 600 kit for my 69 Mach 1 with a 521 CJ. I have the factory clutch pedals but am going wtih a cable setup. Both can tell you what you need and sell kits and individual parts. There setups are complete from bellousing to driveshaft to include linkage question based on your app.
mustang4665 is offline   Reply With Quote
02-04-2008, 11:33 AM   #3 (permalink)
My427stang
I run one behind my 489 FE in a 70.
Its an easy swap, I run factory clutch linkage with heim joints instead of bushings
You have to trim the shifter hole slightly, trim the floor crossmember about 1/2 way across its with (not the tranny crossmember but the floor has a brace itself above the tranny) and you have to shape the floor (BFH) directly under the radio (Easy to do and still keep it looking nice)
Then its literally a bolt in for a 4 speed. I even used my same driveshaft
I do NOT recommend using the drop down crossmember that avoids cutting. It puts the engine and tranny at a steep angle, and on my FE the fan would have hit, and it certainly didnt look right in the shroud.
Angle the motor and tranny as it is from the factory and it will be good to go
I used Dark Horse Performance for parts
70 Sportsroof, 427 FE/489 cid, 10.7:1,Ported Edelbrock heads, and RPM intake, 1000 Holley HP, Ceramic Hooker Supercomps, TKO-600, 3.70, A/C
02-05-2008, 09:55 AM   #4 (permalink)
marvsfords
Thanks alot for the great info. Great to here it from somone that has has done it!
02-05-2008, 09:59 AM   #5 (permalink)
marvsfords
thanks mustang 4665.
03 Mach 1 seats in 69 Mach 1 19mach69 All Ford Techboard 5 10-20-2006 07:20 PM
VIN #s on 69 Mach 1 63SportsCoupe All Ford Techboard 4 11-09-2005 06:29 PM
06 mach one??? kt351 The Garage 4 06-25-2005 01:11 AM
69 Mach 1 Anyone? tim1859 The Garage 3 04-14-2003 07:30 PM
5.0 and C4 into a 69 mach 1 sinistertrucker All Ford Techboard 2 01-23-2003 10:51 PM
