02-03-2008, 03:41 PM   #1 (permalink)
65blkvert
65 instrument bezel replacement
my instrument bezel has lost all its chrome and I want to replace it with an aftermarket one but when I looked under the dash I wasn't sure It could be accessed without removeing everything . Is there a procedure for replaceing a bezel?
thanks
65blkvert is offline   Reply With Quote
02-03-2008, 09:54 PM   #2 (permalink)
foleysfriend
Re: 65 instrument bezel replacement
I changed my 66 bezel by removing some screws holding it on to the dash. I think there are 6 or 8 holding it on. After the screws are out you have to reach under the dash and loosen the speedo cable nut . I didn't have much slack in the cable to pull the bezel forward and remove the cable. Make sure you use tape to mark all the wires to the instruments. Also it is a good time to get a new lens and change the bulbs and bulb covers. There are new colors different from stock if you like. Check out the new white decals you can apply if you don't want that stock black background.
Greg
02-04-2008, 09:54 AM   #3 (permalink)
65blkvert
s
o if I c
an remove
thespeedo cable from under the dash that will allow me to p
ull the bezel away from the dash to disconnect the wires from the front?
02-04-2008, 12:11 PM   #4 (permalink)
65blkvert
Thumbs up Re: 65 instrument bezel replacement
thanks foleysfriend it came right out
02-04-2008, 08:31 PM   #5 (permalink)
foleysfriend
All the best in your project
Greg
I need a T handle and bezel FEandGoingBroke Mustang Pages (1965-1973) 5 04-02-2007 09:12 PM
dash bezel neverfinished Mustang Pages (1965-1973) 4 03-28-2007 08:10 AM
67 gal BEZEL fast67ford Galaxie Pages 1 05-29-2005 12:50 AM
will a 66 bezel fit a 65 my1st65 All Ford Techboard 3 07-16-2003 09:24 PM
Dash Bezel replacement Ponygirl67 All Ford Techboard 2 07-31-2002 08:00 PM
