Re: clutch cable conversion
I put one in my 67, Modern Driveline, piece of cake! Used a Lakewood bell and Fork, came with the pivot ball. Had to modify the bell a lot, as most scatters do require that.
Headers were a pain, had Hooker Super Comp long tubes, they wont work with the cable on a 351, you may be able to do it on a 302. I wound up using Heddmans and have tons of room and the cable doesnt come close to the header. I like it, it takes a bit of getting used to as the mechanical clutch had more sensitivity to it at the friction point, this one seems to jolt a bit when it engages, only once in a while, but its way smoother and easier.
You will like it.
 Gydyup - 67 Mustang Coupe
\"old School\"
