02-10-2008, 06:44 PM   #1 (permalink)
Roadkill
Lock Striker Pin
Just installed a new passanger side door from NPD on my 66. The striker pin lifts the door when closed. Im having a little trouble loosening the screws that hold it in place. Anyone have a trick to help me with this. Thanks Ed
Roadkill is offline   Reply With Quote
02-10-2008, 11:12 PM   #2 (permalink)
Re: Lock Striker Pin
You need a pair of BFV 's (big farkin Vicegrips...)
The screw is hard to bust loose and if you have the bolt nut and plate type it's hard also...
Grunt a lot, it usually works...
FE
02-12-2008, 12:57 PM   #3 (permalink)
289dual4s
It is what I use to take the screws on and off....
Craftsman Impact Driver - Model 47641 at Sears.com
http://smg.photobucket.com/albums/v404/57fairlane/57%20Ford/?action=view&current=MyMustang002-1.jpg
289dual4s is offline   Reply With Quote
02-15-2008, 08:17 AM   #4 (permalink)
kechke
Once you get them out replace them with Flat Socket Head Cap Screws of the same dimensions, as long as you are concours specific.
Non Illigitimus Carborundum
68 convertable
05 convertable
kechke is offline   Reply With Quote
02-15-2008, 08:42 AM   #5 (permalink)
You could alway's adjust the door to make it fit the latch
02-20-2008, 10:35 AM   #6 (permalink)
d_ford
When the door latches closed, do the body lines line up or is the door too high at the rear where it meets the quarter panel? If the body lines are correct, you'll need to adjust the door up at the hinges. If the door sits too high when closed you'll have to adjust the striker down. If you adjust the striker, be sure you use the correct phillips screwdriver to fit the screws, if it doesn't fit correctly you could strip the screw heads. I keep tension on the screwdriver to loosen and strike it with a hammer.
Doug
'07 Shelby GT500, '68 mustang fastback 427 tunnel port,'68 mustang coupe
'95 SVT Cobra, '77 Cobra II drag car, 67 Shelby GT500 - sold
d_ford is offline   Reply With Quote
67 ranchero striker tailgate ranchero67 Wanted 1 02-02-2008 11:49 AM
Stall converter speed, lock or non-lock for 302 with AOD slik Torino Pages 2 09-01-2005 08:06 PM
traction lock ? 70 stang All Ford Techboard 4 02-19-2004 09:06 AM
vapor lock ggroth9 All Ford Techboard 11 08-30-2003 09:16 AM
Lock up or no Lock up Vic All Ford Techboard 6 01-25-2003 01:24 AM
