02-15-2008, 01:35 AM   #11 (permalink)
KULTULZ
Post Re: 1969 Shaker Intake
Originally Posted by KULTULZ
You do understand the air being drawn into the engine is unfiltered, correct?
ADDED: This meaning air drawn through the flapper.
The flapper feature is only need at WOT or near for a performance gain.
Your application has a flexible tube that draws air from the core support area? That is your ram air effect. This will apply to ram air applications also.
Originally Posted by jetnoise View Post
I don't believe this to be correct
never seen flexible tubing running to the core support on any 69/70 car I have seen.The only flexible tubing would be for the heat riser if you have one at all atatched to your exhaust manifold.
I believe the ram air is the function of the scoop not the air cleaner snorkle.
I can tell you there is a noticable differance on my car with the shaker installed vs not.
The flapper opens on loss of vaccum caused by wide open throttle. There would probably be no benefit for it to be open just putzing around town
Please expound on your statement.
There was no provision for fresh outside air on your MUSTANG (other than the SHAKER flapper). A system would have to be devised. You want to keep the choke stove hot air feature for cold air operation. There is a flapper in the snorkel that cuts off the heated air when regular operating air temperature is achieved.
Any car will operate better off of outside (engine compartment) air rather than engine compartment air. The one poster needs to study the theory of ram air.
[FONT=Century Gothic][/FONT]
02-15-2008, 06:59 AM   #12 (permalink)
KULTULZ
Red face Re: 1969 Shaker Intake
I don't believe this to be correct.
And I believe you are correct. I forgot about the air cleaner lid under the flapper plate that diverts the incoming air to the outer area of the air cleaner to be drawn through the air filter.
I was wrong here...
Actually, having the flap stay open does allow for continuous fresh air (only a mix of heated engine compartment air) and explains the air filter element getting dirtier than before.
Again, I apologize for any confusion I have caused.
02-15-2008, 07:10 AM   #13 (permalink)
KULTULZ
Below is an AUSTRALIAN Shaker Setup. Notice no snorkel?
02-15-2008, 10:02 AM   #14 (permalink)
alanmacdougall
Take a look in FMwire at the Falcon GTHO Phase III article. There is a picture of the shaker with the snorkel blocked off. The flapper has to be removed or the engine wouldn't get any air. This looks like a factory setup. I would expect Aussie Ford did there homework on this. My 418w loves the colder air all the time.
alanmacdougall is offline   Reply With Quote
02-15-2008, 11:43 AM   #15 (permalink)
dfree383
Originally Posted by alanmacdougall View Post
My original shaker allows air in the snorkel that is heated by the engine and ambient air from the ram snorkel. All air goes through the filter before entering the carb. My engine performs better with only the ambient air. Lets ask the drag racers, will your times improve with with colder air say 60F vs 90F? Without the flapper there is also an improvment in airflow.
Yes cooler air makes a car go faster.
02-15-2008, 04:54 PM   #16 (permalink)
KULTULZ
Thumbs up Re: 1969 Shaker Intake
I also have a shaker on my mustang. I wondered how much performance was lost with the flapper closed most of the time. Since my car is never in freezing weather or in rain, I took the flapper out and covered the warm air intake hole on the side. I believe this is a good improvement but hard to quantify the ram effect. The only downside I noticed is the filter gets dirter faster.
Now that I have recovered from my previous senior moment, what you have done is perfectly acceptable. By blocking the snorkle intake, the incoming air actually pressurizes the air cleaner asm. and runs cooler as it does not mix in any way with engine compartment air.
Neat trick...
02-16-2008, 10:04 AM   #17 (permalink)
marvsfords
I to have a shaker on a 69 and wondered the same.
I have ran at the track with the shaker on & off , it for sure run's better times with it on!
i have left the flapper in place, when Im not at full throttle I want my air filtered.
Shake-on!
marvsfords is offline   Reply With Quote
1969 351w deck height which intake Lupins All Ford Techboard 8 12-28-2008 09:12 PM
Shaker Kit for 87-93 Mustang? Roarnracin Mustang Pages (1979-1995) 3 07-17-2007 01:04 PM
Intake Manifold Height with Shaker? GregS All Ford Techboard 23 08-01-2004 12:24 AM
Shaker Hood set-up 64dlvry Falcon Pages 1 08-25-2003 04:50 PM
70 Shaker Topper Fairlane Pages 9 08-14-2002 11:48 PM
