02-19-2008, 10:50 PM   #1 (permalink)
ajourdin
Unhappy Flywheel imbalance, 351W 4v
I just bought a 1969 M code Mach I (351W 4v) which was converted from A/T to toploader 4spd. The driveshaft wrung off and the tranny failed on the turnpike on the ride home, so I had a mechanic install a Kiesler TKO 500 5spd. He also installed a new Spec clutch and flywheel, and the engine has bad vibration when revved, even at a stop with the clutch disengaged. How can I tell if the flywheel I took out has the 28oz imbalance- is the imbalance the extra lobe cast into the flywheel in an apron shape just inboard of the friction surface? Maybe the Spec flywheel didn't have the imbalance required- can I add that through the bellhousing or does the tranny have to come out?
Any expertise or experience in this area is greatly appreciated.
ajourdin is offline   Reply With Quote
02-20-2008, 12:55 AM   #2 (permalink)
ChicoB
Re: Flywheel imbalance, 351W 4v
All 351w's use a 28oz imbalance. Call your mechanic and see what he used. If it needs to be changed, the tranny will need to come out.
02-20-2008, 07:09 AM   #3 (permalink)
ajourdin
Update: My mechanic neglected to install the screw-on 28 oz. imbalance weight! Has anybody out there ever snuck one in through the starter hole in the bellhousing? That's my next challenge-who out there thinks I can git 'er done?
02-22-2008, 03:49 AM   #4 (permalink)
PaulS1950
I believe that with enough determination and a bit of work you can do it. I would try if it was mine......
when I was younger and had a back that actually bent.....
Paul
Will any 28oz imbalance flywheel work for my 351 C? sharpshot71 All Ford Techboard 9 12-12-2005 08:13 PM
351W flywheel+head question 71LincMK3 All Ford Techboard 5 09-27-2005 07:51 PM
351w flywheel NoLongerHere All Ford Techboard 4 09-15-2003 09:50 PM
28 or 50 imbalance woody All Ford Techboard 3 08-06-2003 04:58 PM
351w imbalance dragman64 All Ford Techboard 1 12-30-2002 08:51 PM
