02-24-2008, 07:04 AM   #1 (permalink)
criscoelectric
302 Water Pump?
Newbie here....Haven't been around gears for over 35 years. It's just like starting over.
I've been resto-moding a 65 Mustang Coupe and found an 88-89 302 roller block to build from.
Plan to run somewhere in the 350-375 HP range.
Eagle forged crank, Eagle forged rods, Speed-Pro forged pistons on the bottom side
Have iron heads with 190CC runners,1.94/1.50 valves. Edelbrock #7121 dual plane Intake. Reserving decision whether to port match these two, I think they're running pretty close as is.
Edelbrock Performer RPM cam #2281 (hydraulic roller), which is the 351W cam and the HO firing order.
Read here that running high volume oil pump is risky for a street engine so I'm running the stock Mustang GT oil pump #M-68. Will probably use an ARP shaft though.
Now, I'm stuck on a water pump. I've read too many horror stories about running hot. That's the biggest reason I went with iron heads instead of aluminum. I'm changing the stock radiator (2 row) out to a 3 row and may even go to an aluminum in the future depending on how hot this beast runs. As you can see, I'm really paranoid about this thing running hot. I know Aluminum dissipates heat better than iron, but it also will warp in the blink of an eye.
What Water pump do you guys suggest? I think a hi-volume is automatic. Any particular brand and model #? Do these run clockwise or counter-clock wise?
criscoelectric is offline   Reply With Quote
02-24-2008, 03:47 PM   #2 (permalink)
frdnut
Re: 302 Water Pump?
A stock water pump should work fine for you..There is no reason to be paranoid about overheating..The aluminium heads would probably have helped the engine disapate heat like you said..Use a good radiator and fan setup..Dennis111 changed the rad cradle in his 65 to allow the fitting of a 67-70 big block style rad with the stock look..You could probably also do some trimming on the stock one to install a bigger rad if necessary.
02-24-2008, 09:36 PM   #3 (permalink)
60smuscle
Re: 302 Water Pump?
I built a semi-warm 302 and stuck it into a 65 Mustang that was an original 260 V8 and used the original radiator. It hasn't really been all that warm in Northern Wyoming but, with a 180* thermostat, the temperature guage stays at approximatly 180*.
02-27-2008, 02:16 PM   #4 (permalink)
MNSJR
Re: 302 Water Pump?
I put a roller cam warmed up 302 w/ 1969 351W 4v heads 1.94/1.60 ss valves and mile port, RPM intake and Edle 600 carb, tri-y headers about 260-275 hp. The stock radiator cools just fine. Constant 180 degrees.
1939 FORD COUPE - 351W POWER
1939 FORD CONVERTIBLE 302/345HP POWER
1966 MUSTANG COUPE - 302 ROLLER W/351 HEADS
ONLY BOYS HAVE BOW TIES
[img]http://www.fordmuscle.com/pics/MNSJR_39.jpg[/img]
MNSJR is offline   Reply With Quote
1965 289 water pump question (aluminum pump) wildosvt01 All Ford Techboard 4 04-14-2007 04:18 PM
water pump 3154tm Falcon Pages 3 02-27-2006 07:23 PM
Damnit! Water leaking AGAIN... Water Pump Backing Plate Seal. Nitmare67 All Ford Techboard 16 01-15-2006 03:08 AM
Is this a WATER PUMP? TheGmKiller331 All Ford Techboard 6 11-17-2004 03:57 AM
water pump Q tonyk All Ford Techboard 4 11-23-2002 11:58 PM
