02-24-2008, 01:03 PM   #1 (permalink)
AIRRIDE
1964 1/2 mustang rasies as you reverse and lowers as you drive foward
My 64 1/2 raises as I reverse the car back and lower as it drives foward.It raises about 2 to 3''.
I have replace the front suspension with a 1'' lower spring,roller perches,roller upper arm,roller lower arm,adjustable rod ends,new shocks,replaced everything except the knucle and drum.and also did the shelby drop.
what could cause this,you can see it moving up as you back the car up.and lower as you drive foward,and also when i put it on the hoist and put it back on the ground the suspension stays up as if i didnt lower the front.it lowers as I drive the car foward after I take it off the hoist.something is not right here.I havent done a alingment yet.
Any idea.........
AIRRIDE is offline   Reply With Quote
02-24-2008, 08:27 PM   #2 (permalink)
dodgestang
Re: 1964 1/2 mustang rasies as you reverse and lowers as you drive foward
Do you have Granada front disc?
Did you get the car aligned since you put the new suspension on?
Nick - 65FB 410c AOD D.T. - 11.521 at 118.85
http://www.dodgestang.com/index.html
Video: http://www.youtube.com/watch?v=c60rI5RWnJw
dodgestang is offline   Reply With Quote
02-24-2008, 08:45 PM   #3 (permalink)
CaptVirgilHilts
Sounds like the parking brake is sticking on to me.
Also did you install complete new upper control arms or just add pivot kits to your existing arms? If you did the kits you may have them cranked too tight. You're supposed to have a piece of steel pipe a certain size across the A arm to avoid squishing the A arms together at the pivot causing them to bind. Ford shop manual states the pipe is to be 6 15/16 inches long.
Sorry that dimension is for a '67 up please check the 65 Shop manual in case that dimension may differ.
Stu
1967 Mustang Coupe
CaptVirgilHilts is online now   Reply With Quote
02-24-2008, 11:18 PM   #4 (permalink)
Yeah... The only thing that makes the car raise and lower while moving is either a HUMONGOUS amount of torque, or the brakes dragging....
FE
02-25-2008, 04:45 AM   #5 (permalink)
KULTULZ
Wink Re: 1964 1/2 mustang rasies as you reverse and lowers as you drive foward
Did you tighten the control arm bushings while they were hanging or did you lower the car before final tightening of the control arms? Sounds like bushing bind to me.
[FONT=Century Gothic][/FONT]
02-25-2008, 05:32 PM   #6 (permalink)
Rcode427
I am sure someone here got it right or will so you can find it soon . I had a 69 mustang once that raised up as soon as I put forward gear in , down as I placed it in reverse . Mine was simple . The U clamps holding the rear end in place , one was broke . If U clamp bolt is broke it will raise and lower the car .
I looked the problem a while . Get someone in car as you change from reverse to forward . You will see the problem .
Foward Manual Valve Body for a C4 notched306 Wanted 0 02-08-2008 08:47 PM
no reverse, reverse is now drive as is nuetral helireefer C4 Transmissions 7 11-09-2007 01:38 AM
Poor idle in Drive & Reverse when applying brakes KjellYrjans All Ford Techboard 7 07-10-2006 09:41 AM
C4 No foward gears?? PLEASSE HELP!! cobras281 C4 Transmissions 2 10-23-2005 08:55 AM
Do eibach drag rear springs and southside lowers work with a light mustang? ed351 All Ford Techboard 0 09-27-2002 04:33 AM
