02-24-2008, 01:56 PM   #1 (permalink)
Fordz
Talking Carb recommendtion
I would love some advice on where to go with this carb. It is a 71 351C 4V in the orginal car, a 71 Mach 1. The previous owner installed a cam, edlebrock high rise, Weber 750 CFM vacum secondary carb and headers. The care came with the "Drag Pack" and factory 4 spd with "Hurst Shifter". The engine loads up with fuel real bad when it idles for over 3 mins.(a long red light) The carb needs work as the engine sputters at high RPM and, it is hard starting after it sits for more than a week. I drive the car a couple of times a month and I love the "gobs of torque" this thing has but I wonder if this is the best set up for this car. Here are my cam specs
Speed-Pro Cam
Intake valve lift .503 Duration 308 Lash HYD
Exhaust valve lift .507 Duration 314 Lash HYD
Rocker Ratio 1.73-1
Distance between lobe centers 108 degrees.
Carb
Weber 750 vacum secondary
Intake
Edlebrock Highrise (medium rise, I don't know the detail.)
Soon to have "Doug's" ceramic coated headers.
Question
Is this a good set up for this car?
I have a brand new Autolite 4300 original 4 barrel for this car, would this be a better carb on this intake and cam conbo?
How much difference in performance would occur if I put the original intake and carb on this config?
Any help would be appreciated.
Fordz is offline   Reply With Quote
02-24-2008, 08:57 PM   #2 (permalink)
barryt1
Re: Carb recommendtion
It sounds like you may have the wrong power valve in it. Have you checked to see what kind of vacuum you are pulling?
70 Fastback
347 Stroker
barryt1 is offline   Reply With Quote
02-24-2008, 09:05 PM   #3 (permalink)
Fordz
I haven't, but I will. What power valve would you recommend?
02-25-2008, 04:23 AM   #4 (permalink)
Mikes66
Before opening anything up, try a few simple things first.
The fuel bowl levels need to be checked. The best way to do that is run the car, warm it up. Shut it off. Unscrew the fuel bowl sites on the front and back, and when you open it, just a little gas should seep out. If none does, try bumping the side of the car a little and see if the fuel spills out.
If a lot comes out, that maybe your problem right there. If you have an aftermarket fuel pump, that could also be an issue, as you maybe making too much fuel pressure.
Lets us know what happens.
[SIGPIC][/SIGPIC]
02-25-2008, 11:30 AM   #5 (permalink)
PaulS1950
Power valve should be about 1/2 what the idle vacuum is.
if you car idles with 11 inches of mercury then your power valve should be opening at 5.5 inches. Holley power valves are stamped with the opening vacuum.
Paul
02-28-2008, 02:36 PM   #6 (permalink)
mustang4665
Speed-Pro Cam
Rocker Ratio 1.73-1
Carb
Intake
Question
Being this car is a 4 speed have you thought about a double pumper? They make great out of the gate throttle reponse. They like gas but kick as if tuned properly. Depending on you gear ratio and which toploader you have, 2.32 or 2.78, a dbl pumper in the 700 cfm to 750cfm range should work out of the box. My 2 cents.
69 Mach 1, 521CJ, TKO;71 Mach 1, 351C4VR/A;66 stang coupe, 306, T-5.
mustang4665 is offline   Reply With Quote
02-28-2008, 08:06 PM   #7 (permalink)
Fordz
You know, I've been told that a 351C can't handle anything larger than a 650 CFM carb. The car now has a 750 vacum secondary Weber, and it really loads up when it idles for anything over 3 mins. With that said, I went on the Holley site, punched in my data, and it spit out a recommendation of a 750 vacum secondary. So I felt pretty good about it. I am still not convinced that I have the best choice, so my question, what would the 750 double pumper add to this package that the current carb doesn't? Thanks.
02-28-2008, 11:28 PM   #8 (permalink)
KULTULZ
Post Re: Carb recommendtion
IMO
You need to source a HOLLEY tech manual and go through the carb to find out why it is idling too rich.
02-29-2008, 12:10 AM   #9 (permalink)
ujt389
people also told me not tput anything bigger on my 302 than a 600. I took advice of people here and put on a 650 DP. It runs incredibly well and makes significantly more power than the old 600 that was on it. Your car could pobibly use a 700-750 DP if you rev it high. Seeing that you have a 750 already, you should tune it up, get the floats right,he righ power-valve, those kinds of things that have been reccomended.
02-29-2008, 06:38 AM   #10 (permalink)
My427stang
Can you verify which carb you have? I havent seen a 750 Weber, but I have seen 750 Holleys with Weber Power Plates.
Does the carb have a number on the air horn?
70 Sportsroof, 427 FE/489 cid, 10.7:1,Ported Edelbrock heads, and RPM intake, 1000 Holley HP, Ceramic Hooker Supercomps, TKO-600, 3.70, A/C
Carb accel pump adjustment. Carb Help 51truck All Ford Techboard 3 05-31-2005 01:42 AM
Which carb float for this carb? beegshot All Ford Techboard 2 06-10-2004 03:05 AM
489ci FE with a Vortec Blowthru Carb Setup Dyno\'d (Great Carb Tech) n2omike All Ford Techboard 12 03-31-2004 02:53 AM
Demon carb q`s-TPC,Bigs and carb guru`s Nastystang All Ford Techboard 8 04-08-2003 03:59 PM
CARB TUNING:All carb "Experts" leave your "Tuning" secrets here!Then we'll all be able to tune'em gtfordified All Ford Techboard 15 04-27-2002 12:26 AM
