02-29-2008, 08:18 PM   #1 (permalink)
AIRRIDE
1964 1/2 mustang C4 tranny bolt up a 1990 302
Will my C4 tranny bolt up to a 1990 302 engine.
AIRRIDE is offline   Reply With Quote
02-29-2008, 08:30 PM   #2 (permalink)
CaptVirgilHilts
Re: 1964 1/2 mustang C4 tranny bolt up a 1990 302
Not if it is from any early 5 bolt block. You may be able to change out the bellhousing to a later 6 bolt style but I can't tell you what other issues you may have. I don't think there are any but I'm no C4 expert!
Stu
1967 Mustang Coupe
03-02-2008, 06:30 AM   #3 (permalink)
PaulS1950
The early 289's used a special flywheel (flex plate) and bell housing you will have to switch to the newer style bellhousing, flex plate and converter. You will also need a later bell housing to bolt to your C4.
Paul
what should i do with this 1990 mustang? Joe30690 The Garage 8 03-08-2005 07:36 PM
dyno 1990 5.0 bolt on fastcars321 Dyno Board 2 01-08-2005 12:45 PM
I have a 1964 Thunder Bolt... what the hell is it? 64ThunderBolt All Ford Techboard 40 08-24-2004 06:02 PM
460 1990 Mustang Questions Canuck All Ford Techboard 1 02-23-2003 08:22 PM
460 Into a 1990 Mustang Canuck All Ford Techboard 1 02-17-2003 12:13 PM
