03-03-2008, 12:34 PM   #1 (permalink)
criscoelectric
Piston Ring Preference?
I'm in the process of gathering parts to build my 302.
I plan on it running 350-400 HP.
There are cast iron, moly and chrome moly rings available. What's your suggestion to which ring type I should use. And Why that type?
criscoelectric is offline   Reply With Quote
03-07-2008, 06:01 PM   #2 (permalink)
67mustangcoupe289
Re: Piston Ring Preference?
i like using cast iron rings myself just because they seat faster and sometimes better, moly and chrome moly ring are harder to seat in the cylinders.... you pretty much have to run the engine without antifreeze, let it get hot, then turn it off and let cool all the way down. you have to do it a couple times to get them to seat properly. thats the only way i found to seat them...unless theres another way
67mustangcoupe289 is offline   Reply With Quote
03-07-2008, 06:09 PM   #3 (permalink)
criscoelectric
Yeah, that's what I'm finding out. It appears Moly rings are for racing applications only... high RPM, hard usage.
03-07-2008, 07:14 PM   #4 (permalink)
jetnoise
I'd ask the piston manufacturer.
Sometimes mfr's like MAHLE pistons are sold or are avail loaded with rings.
70 Mach 1 393W
75 Bricklin 357W
03-17-2008, 01:10 PM   #5 (permalink)
K_Labs
total seal gapless rings... I think hot rod mag did a huge article on them.
1968 Galaxie 500 Less motor and trans! Make me an offer B4 I junk it! super straight body hardly any rust. 4 door sedan!
K_Labs is offline   Reply With Quote
03-22-2008, 08:44 AM   #6 (permalink)
coosbaylumber
I sort of like what Jet has to say here. For replacement pistons today are cut in the bores for certain clearances, and the rings have to match the shrink/expansion of the bore and those particular pistons.
Otherwise you are assuming then that the replacement rings match in with genuine pistons. That is sort of playing mix and match then.
Wm.
Old Ford owner
03-22-2008, 11:14 PM   #7 (permalink)
archoplites
Also consider your choice for use with NA, forced induction, or NO2.
archoplites is offline   Reply With Quote
Forged piston ring gap help fasterdamitt All Ford Techboard 2 03-21-2007 02:43 PM
Piston ring ? 63fair All Ford Techboard 27 01-05-2007 12:34 PM
piston ring? cledusdtrucker All Ford Techboard 0 04-08-2006 08:23 PM
Top Piston Ring End Gap? growlin351w All Ford Techboard 2 07-26-2003 03:30 PM
393 - too much top piston ring clearance? ville All Ford Techboard 2 04-05-2002 08:03 AM
