03-03-2008, 01:07 PM   #1 (permalink)
Ricks67
Driveshaft length??
HI,
My 67 Mustang has the 289 and C4 and 8 inch rear. The rear seal on the trans leaks quite a bit and when I was looking at it the yoke doesn't seem to engage the transmission far enough. Is it possible the driveshaft is from and earlier car and too short? What is the proper length driveshaft for a 67?
Rick
Ricks67 is offline   Reply With Quote
03-03-2008, 04:24 PM   #2 (permalink)
dennis111
Re: Driveshaft length??
Originally Posted by Ricks67 View Post
HI,
Rick
Earlier Mustangs use the same length driveshaft as your 67'. The 351 and larger motors use a 1" shorter driveshaft to accommodate the large yoke on the 9" rearend.
How far out of the tranny does the machined part of the yoke stick out? Typically it should be about 1". If it sticks out a full 2", then there is a problem. Other things that will cause the seal to leak is a bad seal (duh) or the tailshaft bushing can be bad.
Dennis
11.25@122.19mph
03-06-2008, 02:54 PM   #3 (permalink)
Ricks67
Dennis,
Yes, the yoke sticks out at least two inches. I have a new seal but I wonder why the d/shaft is so short.
Rick
Driveshaft length 67mustangcoupe289 Mustang Pages (1965-1973) 1 07-08-2007 12:14 PM
87 5.0 shaft length w/ 85 dizzy. oil driveshaft length? trukstopcowboy All Ford Techboard 7 02-23-2006 08:41 PM
Driveshaft Length FlyByFord Falcon Pages 4 12-20-2005 08:01 AM
t5 swap driveshaft length lakecityg All Ford Techboard 2 05-29-2003 03:27 PM
driveshaft length T5 89gt50 All Ford Techboard 3 02-22-2003 02:04 PM
