03-10-2008, 05:05 PM   #1 (permalink)
frodojv2007
cam help once more please 351c
hi im posting once again for cam help i thought i knew what cam i wanted and now im back to ground zero looking from scratch again im open to hydraulic flat tappet and roller cams. i want to see if i can find a off the shelf cam before i even think about grinding one. i have a
351c 30 over
crank 10/10
rotating assymbly balanced
pistons 10.5.1 compresion
cam pending.............
torker intake
4v closed chambered heads
[SIZE=2]closed valve pressure was 230 pounds and open was 720[/SIZE]
[SIZE=2]2.19 intakes 1.73 exst[/SIZE]
hooker long tubes
stud conversion
1.73 roller rockers
hei dizzy
c6 trany
411 gears
this is going to be a street/strip car i would like to see some horse power above 440 hp at the flywheel. i am just wondering if anyone has a simmilar combo and is running a off the shelf cam im thinking around 110 to 114 lobe seperation and my rpm range to be from 3000 to 6800 rpm any where in that range would be fine. i just need some help choosing a cam i have researched alot and still am having troube choosing the the right cam for my set up any info would help again im looking for off the shelf cams
1964 falcon futura
351c powered one day 302 in it right now
frodojv2007 is offline   Reply With Quote
351C /w Aussies: Please help /w Spark plug T*, Chris Kelly or other 351C ppl. SteeLDawN All Ford Techboard 5 04-20-2003 04:38 AM
differences of 351C ´70 and 351C ´72 zICRONIx All Ford Techboard 3 11-28-2002 07:45 PM
New cam for a 351C 4V? zICRONIx All Ford Techboard 4 09-05-2002 06:03 AM
351c in a GAL coolfalcon The Garage 2 09-03-2002 05:03 PM
351C TbirdSpecial All Ford Techboard 1 05-30-2002 06:12 PM
