03-11-2008, 12:12 AM   #1 (permalink)
S3TH
Question 8" rear end capabilities?
hey does anyone know what kind of power a stock 8" rear end can handle? the guy i got the car from said it had an 8.8" but i know it isnt so im assuming its just the 8" and i need to know whether i need to invest some money upgrading it to handle the power im putting through it, i appreciate any information you can give me
S3TH is offline   Reply With Quote
03-11-2008, 01:17 AM   #2 (permalink)
Sponge
Re: 8" rear end capabilities?
I asked that a few times ago.
http://www.fordmuscle.com/forums/all...-rear-end.html
03-11-2008, 01:43 AM   #3 (permalink)
S3TH
thanks i tried the search function for the forum but there were just to many hits to sort through i appreciate the help
03-11-2008, 02:33 PM   #4 (permalink)
mustang4665
How much power are we talking? A good 8" can handle up to 550HP with the right parts! If you are running a small CID smallblock, it isnt going to make but so much torque, you are probably fine. If it is an automatic, 28 spline axles and a traction lok (Posi) for an 8" inch should do nicely.
69 Mach 1, 521CJ, TKO;71 Mach 1, 351C4VR/A;66 stang coupe, 306, T-5.
mustang4665 is offline   Reply With Quote
03-11-2008, 03:56 PM   #5 (permalink)
S3TH
the rear end is stock as far as i can tell, and i havent had a chance to dyno its an auto with a shift kit added
03-14-2008, 05:47 AM   #6 (permalink)
barryt1
I'm running an 8" in my car, with no problems so far. I replaced the ring/pinion with Motive Gear 3.80, richmond lock-rite locker, stock axles. App. 400 hp 347 stroker motor, running in the mid 12's w/Mickey Thompson ET Streets. C4 transmission. Good luck.
Barry
70 Fastback
347 Stroker
barryt1 is offline   Reply With Quote
03-14-2008, 09:56 AM   #7 (permalink)
S3TH
thanks for the info, im glad there are so many helpful people on this forum
03-14-2008, 02:59 PM   #8 (permalink)
ckelly
The higher the ratio you put in it, the quicker you'll break it. The pinion gets pretty small about 4.11. An auto will hold out better. If you're racing on slicks with an auto, you'll eventually break the pinion. If you're making a lot of power, you can blow out the caps. If you have a stick, fergetaboutit. You can bust an 8 in a mid 13 second car with a nasty shift.
8.8" rear end help S3TH Mustang Pages (1965-1973) 5 02-27-2008 08:15 PM
70' 2dr HT rear Quarters fit on a 69' 2dr "sports top" HusH Galaxie Pages 2 02-05-2008 11:48 PM
Will an 8.8" rear bolt up to 1995 Mustang LX rear mounts? blykins Mustang Pages (1979-1995) 5 01-24-2008 08:27 PM
8" rear measurement Flat32 All Ford Techboard 0 11-14-2007 05:15 PM
need help for 9"rear axles olds55 All Ford Techboard 1 08-05-2007 11:43 PM
