03-22-2008, 06:30 AM   #1 (permalink)
scotts68coupe
Paint or undercoating??
hey guys, I'm going out to clean the underside of my 68,my? is once i get all the surface rust off and weld in new what needs to be,what should I put back on the car to help keep from rusting again? My car will be drove alot,shine or rain,if the heater works and the lights and wipers i drive it.so what do you think ,paint or undercoating
Thanks Scott
scotts68coupe is offline   Reply With Quote
03-22-2008, 09:07 AM   #2 (permalink)
Humphrey351
Re: Paint or undercoating??
What I did with one of my Mustangs was to use an Epoxy primer...just to seal it up nice, and then I did some undercoating over top to make a good protection barrier...might have been overkill, but I wanted the peace of mind.
A friend of mine has the idea to use the Rhino lining to undercoat his car...says if it's tough enough to protect the bed of his truck which is hit with some rough conditions...most of which is wet, should do a bang up job on an undercarriage.
Don't know it any of that helps...good luck!
Mike
03-22-2008, 11:13 PM   #3 (permalink)
Hump did right by his. Epoxy Primer and undercoating spray
Can't bet twice good
03-24-2008, 01:40 PM   #4 (permalink)
71stang99
I gutted the interior on my last two mustangs, pulled out the sound proofing material and wire brushed the entire floor pan area. Put POR15 on and once that dried rhino coated the entire area including the transmission hump. Underneath cleaned off all of the loose factory undercoating and went with the professional grade spray coating underlining. Turned out nice.
71stang99 is offline   Reply With Quote
Undercoating meo954 Torino Pages 3 10-05-2006 06:50 AM
undercoating fast67ford The Garage 7 07-17-2005 05:46 PM
How to remove undercoating? ShotRod64 Galaxie Pages 9 04-06-2005 09:25 PM
Undercoating or POR or ??? for new (used) car? kywookie All Ford Techboard 11 09-29-2003 09:31 PM
Undercoating Bossman All Ford Techboard 6 08-28-2003 04:21 AM
Probe Industries
