Re: 351C Advice
Originally Posted by 71stang99
I have a 351c in a 72 Mach. I bought the car a couple of years ago and it sees very light driving, the motor was supposed to have been rebuilt and I have put maybe 5k miles on it since I have owned it. I have put a MSD distributor on it and a 700 holley carb with edelbrock intake and headers. the car has a stock cam and the 2v heads.
My dillema is that I want to keep the 2v style heads so I was thinking the australian heads (powerheads.com) or do you folks have another route to go with the heads?
The next thought is a cam to go with the type of heads and mods listed above, what would be the best choices? car will be a weekend hot rod, not a strip queen but something that should sound and perform well on the street with civil manners.
It has the FMX tranny (wan C6) and I plan on upgrading the 9" rear end to a posi 3.5 or wquivilant ratio.
thanks!
There is nothing wrong with the 2V heads the way they are. You're definitely going to need more cam for the carb. There also no reason to swap the FMX for the C6. Check out this forum, it's all things Cleveland and is the best resource for building a C. Ford 335 "Cleveland" Series Engine Forum
'73 Mach 1. '70 M code 351C, TKO 600, Blue Thunder,Holley 700 DP, Hooker, Crane, Sub-frame connectors, MSD,'71 bumper, grill, valence.
