Re: Timing keeps messing up
75......
Quite some time ago, I had a Mallory distributor that used to cut off the roll pins. Engine just started up rough one morning then, but noon it was out of action. (OH, baby, just hang in there until the weekend when I can fix you)
The main drive shaft up inside where the bushings are at was not getting lubricated well. Would take a good 2000 miles to goo up and then gice the friction. Oiled the bushings up and reduced drag, and reduced effort to shear that pin off again. The Mallory had external oiling spud, but that did little good. I drilled the bushing for oil, and then when I dripped some in from outside, it actually got to the bushing. No problems after that.
Wm.
Old Ford owner
