05-05-2008, 01:55 PM   #1 (permalink)
machwon
Cool 8" too short in a 67 fastback
I have a 67 mustang with a 8" rear end that seems to be out of an early 66 mustang it measures 52" flange to flange I've been told that it should measure 54" is this correct
machwon is offline   Reply With Quote
05-05-2008, 07:49 PM   #2 (permalink)
CaptVirgilHilts
Re: 8" too short in a 67 fastback
Was your car originally a 6 banger? maybe the 8" was swapped in from an early V8 car. It should be 54" you're correct
Stu
1967 Mustang Coupe
05-06-2008, 10:14 AM   #3 (permalink)
dodgestang
You can still use it the perches will be in the correct location.
If you are ordering custom wheels for the rear simply subtract 1 inch of back spacing...so a 17x8 that you would normally order with 4.75 would need to have 3.75 bs. The other option is to just bolt on some 1 inch adapters to make up the difference. I am intentionally putting a 65 width rear in my 67 so that I can run a much deeper dish rim in the rear.
Nick
65FB 410c AOD D.T. - 11.94 @ 112.6
http://www.dodgestang.com/index.html
dodgestang is offline   Reply With Quote
05-08-2008, 10:54 PM   #4 (permalink)
mc
Yeah, I just put a granada rear in my 67 and it's about 3/4" narrower on each side. I'm going to get some spacers for my wheels since I already had them!!
62 Comet wgn-289/AOD/Pdisc
64 Vespa-186cc big bore cyl/expansion chamber/24mm carb/stroker crank/upgear kit/elect ign-- 13-15HP(stock 5hp)!!!
mc is offline   Reply With Quote
1970 Torino Fastback "M" Code For Sale arogant Vehicles for Sale 3 05-07-2008 10:25 AM
1973 Ford Gran Torino Sport "Q" code jjj2007 Torino Pages 6 01-28-2008 07:19 PM
1977 LTD II, S-code ["SPORT II" clone project] $1200 MERCURYMUSCLE Vehicles for Sale 1 01-14-2008 04:28 PM
Disc swap prop valve, "T" fitting questions ? lgh1157 All Ford Techboard 3 01-01-2008 10:28 PM
"Victory by Design" on Speed, Ford Muscle series ga289stocker The Garage 0 07-08-2007 09:35 AM
Holley
Holley
