05-16-2008, 02:33 AM   #1 (permalink)
Turboavi
Question Istalling new tach
i want to install a tach on my 289 automatic. how would i go bout doing that.
Turboavi is offline   Reply With Quote
05-16-2008, 05:03 AM   #2 (permalink)
frdnut
Re: Istalling new tach
Do you mean factory or aftermarket?...Can't help you with factory but aftermarket is very simple...Normally you have a red wire that needs to go to a switched 12 volt source..One black wire that goes to a ground..One white wire that goes to your interior lights or can be hooked in with the red wire if you want the light on any time the key is turned on...And one green wire that you hook to the negative side of your coil....The tach can easily be mounted to your steering column with a big hose clamp....Most tachs have an internal switch that needs to be set for your engine size (4-6-8 cylinder)..
05-16-2008, 04:42 PM   #3 (permalink)
CaptVirgilHilts
If you have a 67 68 Mustang then you could get tach from these guys that goes in the clock space.
Mustang Mini-tach
Stu
1967 Mustang Coupe
05-16-2008, 06:02 PM   #4 (permalink)
Turboavi
i should have been more specific. Its a 68, and did not originally come with any wiring for a tach. Will i need some sort of sender unit, and where will i need to install it. i was planning on puttng aftermarket gauges on it.
05-16-2008, 08:10 PM   #5 (permalink)
CaptVirgilHilts
No sender, just like Frdnut said to the negative side of the coil.
Stu
1967 Mustang Coupe
Tach hookup lds79ford Fairlane Pages 2 04-06-2008 04:17 PM
67 Tach Hookup with MSD Tach Adapter joesgt281 All Ford Techboard 4 06-01-2007 08:00 PM
How does a Tach do what it does? Cyclone Joe The Garage 9 11-19-2003 04:59 PM
tach 64 TBOLT The Garage 1 01-12-2003 01:24 PM
4" Tach? coupe3w The Garage 6 02-17-2002 05:46 AM
