05-18-2008, 09:43 AM   #1 (permalink)
barryt1
Aluminum driveshaft ?
Have any of you guys taken an aluminum driveshaft out of a late model car from the junk yard and had it modified to fit a 67-70 Mustang? I wonder if there are any out there that would work with a C4 that could just be shortened? I don't recall ever seeing a post on this topic, so forgive me if there is an obvious reason why it won't work.
Thanks,
Barry
70 Fastback
347 Stroker
barryt1 is offline   Reply With Quote
05-18-2008, 01:30 PM   #2 (permalink)
tweet66
Re: Aluminum driveshaft ?
I used anAerostar aluminum driveshaft when I did my T5 swap in my 66. I had it shortened about 4" to fit my setup and used the C4 yoke (cut down). I haven't had an oppurtunity to try it out yet though.
tweet66 is offline   Reply With Quote
05-19-2008, 06:05 AM   #3 (permalink)
barryt1
Hey, thanks for the info! I think this will be a pretty cool and easy upgrade. Shed some weight, and looks much better too.
Barry
70 Fastback
347 Stroker
05-19-2008, 03:17 PM   #4 (permalink)
galaxie
Less rotating mass! Always a good thing.
59,60,64,66,68 Full size fords
87,93 5.0 Mustangs
05 Lincoln LS8
WTB: 1960 Ford Wagon
Pittsburgh PA
galaxie is offline   Reply With Quote
05-21-2008, 07:13 PM   #5 (permalink)
nickgt350
late model crown victoria has a 3 1/2 inch alluminum drive shaft pull a part junk yard 13.00 dollars 75 to cut it down and re weld it
nickgt350 is offline   Reply With Quote
05-22-2008, 03:24 PM   #6 (permalink)
PaulS1950
Aluminum driveshafts won't take much torque without damage. The u-joint yokes spread easily. They also begin to work harden as soon as you start to use them - definitely not a long term solution to anything. I will stick to steel from here on.
Paul
05-22-2008, 05:57 PM   #7 (permalink)
mustang42782
I have an aluminum in my car that sees strip time often. It is SFI certified, and has been inspected every year or so for recertification. 6 years later, no problems. We also run the same aluminum DS in our dirt late models, dont have any problems there either. Not to mention that there are several vehicles from the factory with alum shafts that have 100k miles on them, this includes trucks as well.
05-22-2008, 08:00 PM   #8 (permalink)
barryt1
Wink Re: Aluminum driveshaft ?
You definitely have to match the driveshaft to the application. I have a friend with at race car that twisted a 3 1/2" aluminum driveshaft. He went to a 4", and has not had anymore trouble. He is running between 850-900 hp. All aluminum driveshafts are not created equal. My car has around 400 hp, with a C4 transmission, I think a stock 3 1/2" should be OK.
Barry
70 Fastback
347 Stroker
Where To Buy Aluminum Driveshaft MARTYMIZE All Ford Techboard 5 09-11-2007 05:47 PM
one piece aluminum driveshaft? fomocoro Mustang Pages (2005) 16 08-31-2007 06:27 AM
aluminum driveshaft better? slyman2087 All Ford Techboard 7 06-03-2005 02:08 PM
Aluminum Van driveshaft ?? TBoltII Fairlane Pages 2 01-17-2005 12:45 AM
aluminum driveshaft noslofoord All Ford Techboard 5 08-01-2002 09:32 AM
