05-20-2008, 02:06 PM   #1 (permalink)
Donnan408
Some advice..?
Looking for a bit of guidance.
Just finished building a 352 stroker. Forged everything. Comp Cam (nitrous/blower ground). AFR 185s, Air gap intake and 600cfm edelbrock.
I have a 8.8 rear (yes i know, but it's light), and 3.08 gears. 215/50/15 tires.
Traction bars and subframe connectors. 5 speed with a RAM Clutch 3 finger 900lb springs i believe.
What is my next move? I kind of want to save and do a 4 link, but then I also want to throw some nitrous on it, but then I want to do a supercharger/turbo.
I was really thinking for right now. new gears (3.55s) and some ET streets on a extra set of rims.
Thanks for the help guys!
Std 302 for now. I am setting aside money for a DART block that I have on hold from a friend who works for a restoration shop. Really good deal. But I do not forsee me needing it yet.
Yes I know the 600 seems small. But I was told and agree with that it will work well until I decide to go blow through, etc.
The RPM range is tough. idle-6000?
It's a street car basically, but I certainly do not mind good all around manners. Ok, more track than street. Street/strip lets say.
The motor is quite strong I must say. Forged crank, forged H beam rods, forged Mahle pistons.
Here's the specs for the cam.
Compression comes out to 9.0-9.1: 1
AFR 185s
1.6 RR
Anything else needed let me know!
Donnan408 is offline   Reply With Quote
05-20-2008, 03:06 PM   #2 (permalink)
barryt1
Re: Some advice..?
From reading your post, you know what needs to come next! 3.73 gears, and a locker if you don't already have both tires working for you. Going to an electric fan is a pretty easy upgrade that will free up another 20 HP. And that 600 cfm has got to go, and soon!
Barry
70 Fastback
347 Stroker
barryt1 is offline   Reply With Quote
05-20-2008, 05:21 PM   #3 (permalink)
hepcat69
Re: Some advice..?
Sounds like a pretty sweet set up. I would definately go with the gear swap. Makes a hell of a difference. Do you plan on taking it down the track. Update with some times and some pics
Hey Kid. Shut up and gimme your lunch money.
hepcat69 is offline   Reply With Quote
05-20-2008, 06:24 PM   #4 (permalink)
Donnan408
Re: Some advice..?
yea. gear swap is next.
ordering them today.
Going to start putting money away for a custom carb (or a nice off the shelf blow through).
3.73s?
05-20-2008, 07:37 PM   #5 (permalink)
barryt1
Wink Re: Some advice..?
3.73s?
At least 3.73, why would you build a performance motor and not give it some gears? Are you going to be doing a bunch of interstate driving with this car? As far as the carb goes, a Quick Fuel Technology 750 Q series would do you a really nice job! Outstanding quality carburetors
Barry
70 Fastback
347 Stroker
05-20-2008, 09:20 PM   #6 (permalink)
Donnan408
Re: Some advice..?
Well yes and no.
I like doing freeway rolls (empty mexican roads of course), so I don't want to kill my ears.
I think 3.73s sound good.
Good street and not that bad highway.
05-21-2008, 06:26 AM   #7 (permalink)
barryt1
Re: Some advice..?
3.73 are a good mid range gear, IMHO, not too high, not to low. With 3.73's you'll probably be around 3500 RPM's at 70 mph. You never did say whether you have a locker in your rear end????
70 Fastback
347 Stroker
05-21-2008, 07:47 AM   #8 (permalink)
Donnan408
Re: Some advice..?
oops. sorry. I have trac loc. Works decent.
05-21-2008, 07:04 PM   #9 (permalink)
ujt389
Re: Some advice..?
If you have a 5 speed with a .68 overdrive like me I would go with at leased 3.73's. If I were gearing my car again i would go with 4.11's. Dont bother with the 4 link unless you turn it into a race car. Ive seen 10 second cars launching on leaf springs. Also a 750 double pumper holley will get you lots of power. the 600 edelbrock is killing your power.
05-21-2008, 08:41 PM   #10 (permalink)
barryt1
Re: Some advice..?
Yep, I agree. That's a lot of money invested in a darn good set of heads to have an Edelbrock 600 cfm carburetor.
70 Fastback
347 Stroker
cam advice please hotrodconsolo All Ford Techboard 0 04-01-2008 06:49 PM
Need advice on 2V heads. Also cam advice. Rancho Lenny All Ford Techboard 3 10-22-2004 09:51 AM
help /advice giddyup1 All Ford Techboard 3 07-28-2004 08:39 AM
New guy needs some cam advice 79merc All Ford Techboard 5 10-18-2003 05:20 PM
My first 460 Advice please ScreaminC All Ford Techboard 1 04-29-2003 12:36 PM
Holley
