05-22-2008, 08:37 PM   #1 (permalink)
hepcat69
Shifting Problems
I just a 4.30 gear behind my '69 351w fmx. when i put it in drive, it shifts into 2nd around 4500-5000 rpm(thats with the throttle matted) pretty good but from 2nd to 3rd, the transmission will go up to just under 6000 and i have to let off and then it shifts. its not freewheeling like a band adjustment and ive got vacum going to the modulator. And the vacum modulator is not out of adjustment. im pretty familliar with this. The thing is, it shifted perfect before i put the gear in. Would it have anything to do with the governor or valvebody? any ideas?
Happieness is defined as daylight under the front tires.
hepcat69 is offline   Reply With Quote
05-25-2008, 01:54 AM   #2 (permalink)
PaulS1950
Re: Shifting Problems
It is the governor. Your change in gearing makes a difference. There is a different governor that can bring the RPM down a bit. I wish I could remember the number - I am unsure if i have it but I will look.
Paul
05-28-2008, 10:46 AM   #3 (permalink)
hepcat69
What would you suggest I do?
05-30-2008, 04:58 AM   #4 (permalink)
PaulS1950
Change the governor.
cut the rod on the vacuum modulator down 1/16".
Build the engine to turn faster.
I think those are your only choices other than just living with it.
Paul
C4 shifting problems xcgxl C4 Transmissions 16 10-25-2007 03:31 AM
c-4 shifting problems Mike545 All Ford Techboard 5 11-11-2003 06:34 AM
c6 shifting problems aaron All Ford Techboard 3 08-10-2002 12:37 PM
C4 Shifting Problems? stang69sk All Ford Techboard 5 05-24-2002 11:20 PM
c-4 shifting problems Mike545 All Ford Techboard 0 04-22-2002 11:15 AM
