05-27-2008, 09:13 PM   #1 (permalink)
66svt
66 coupe
Can I fit a 67 rear end on my 66 with out any fabrication. Can it be a weekend job or will it take more time to install.
Thank you.
66svt is offline   Reply With Quote
05-27-2008, 10:23 PM   #2 (permalink)
PaulS1950
Re: 66 coupe
The spring perches will bolt right up but axle is slightly wider and may require a different offset for the wheels to keep them under the fender. Everything else should work fine.
Paul
05-28-2008, 12:09 AM   #3 (permalink)
gabe1530
Re: 66 coupe
like paul said, you might have to use a different offset wheel. the wheels might stick out quite a bit if not. the 67 and up rear ends are 2 inches wider than the 65/66's.
66 coupe. 5.0 block. edel rpm heads, z-303 cam, crane rr, pro flo efi, lt headers. t5 and currie 9 inch, tcp coils, 5 leaf rev eye, caltracks, watts link, and 4pt. rollbar. next: subframes, & slicks!
gabe1530 is offline   Reply With Quote
68 coupe scotts68coupe Wanted 0 05-13-2008 07:24 AM
Hey some ???s about my \'73 coupe sharpshot71 Mustang Pages (1965-1973) 3 08-27-2005 09:00 PM
67 coupe agawam Falcon Pages 8 08-15-2005 03:42 AM
33 coupe blown33 All Ford Techboard 18 07-06-2004 02:16 AM
Where\'s 89 Coupe? coolfalcon The Garage 29 08-04-2003 07:10 PM
