06-04-2008, 02:53 AM   #1 (permalink)
4Lowie
Rod bolt upgrade
Hi all.
If I wanted to install 3/8 bolts in some 289/302 rods can I just drill them out to suit? Are there any casting differences between the hipo rods which have the larger bolts?
4Lowie is offline   Reply With Quote
06-04-2008, 05:48 AM   #2 (permalink)
dennis111
Re: Rod bolt upgrade
I gave you an answer in the Stroker section that you posted in.
By the way, multiple posts are not needed on this site in order to get replies.
Have a nice day!
Dennis
11.25@122.19mph
06-05-2008, 01:43 AM   #3 (permalink)
beegshot
Originally Posted by dennis111 View Post
...multiple posts are not needed on this site in order to get replies...
dennis111, I respectfully disagree with your opinion. I have had great success with getting the requested information I need by posting both in this forum and the all ford tech board. I should, however, add the following caveat. I normally state in one thread or the other that I am "double posting", and I will keep both threads updated with the latest information. That facilitates the seldom used "search function".
My $0.02.
Robert
http://www.fordmuscle.com/pics/beegshot_a.jpg
Beegshot
2 - 65 'stangs, 79 F100 SuperCab, 03 Expedition
Henry Ford said, "If you find you need a tool, you have already paid for it."
06-05-2008, 07:12 AM   #4 (permalink)
PaulS1950
There is not enough rod material to drill to 3/8" but it is common to go to a special 11/32" rod bolt on the 289/302 for added strength. You should not drill them yourself - have it done by a machine shop where they use a mill to properly ream the holes.
Paul
Rod bolt upgrade 4Lowie Stroker Engines 1 06-04-2008 05:45 AM
What year did Ford switch from 3 bolt to 4 bolt crank balancers? Frank Mustang Pages (1965-1973) 6 10-31-2006 08:00 PM
What year did Ford switch from 3 bolt to 4 bolt crank balancers? Frank Truck Forum 2 10-27-2006 10:12 AM
engine upgrade/see spring upgrade? elsanyo All Ford Techboard 6 02-15-2006 05:59 AM
Bolt size to bolt motor to engine stand? Brian M All Ford Techboard 5 05-31-2005 06:42 PM
