06-09-2008, 12:52 PM   #1 (permalink)
Eeyore
In-Dash Tachometer
I'm sure this is a stupid question... but....
I have a 68 coup that does not have a tachometer. There is only one small gauge opening left in the stock dashboard. After a bit of looking, it seems pretty hard to find a tach that fits in the small opening (or maybe I'm just looking in the wrong place). Anyway, what is the best solution for putting in a tach? Find a small one or try to rearrange the existing gauges to put the tach in the large right hole (where the fuel and voltage is)?
Optimally, I would like it to look pretty "normal".... not too high tech.
Suggestions for tach's (on a budget)?
Eeyore is offline   Reply With Quote
06-09-2008, 02:43 PM   #2 (permalink)
frdnut
Re: In-Dash Tachometer
There are small tachs that will fit in the clock (center) small opening in the upper gauges..I have seen them on ebay..They may not be too accurate though but any 2 1/16th sized guage should fit in that opening...If you put a tach in the larger gauge opening in the bottom you will lose your gas guage on the 68 model....For that reason I have stuck with the tach on the steering column with a hose clamp but I am looking at more options with shift lights and such..
06-09-2008, 04:16 PM   #3 (permalink)
CaptVirgilHilts
Mustang Mini-tach
OR you can just buy a small aftermarket gauge and use the clock blank off face and mount the tach to it. You'll need to pull the needle and face off it then drill the clock blank then sandwich it between the tach face and workings. You'll need to trim the gauge enclosure too. I just bought a cheapy one ($20) and did that. I don't need the tach really it's just there for looks and that clock blank is useless anyway! The script style isn't quite the same on mine but pretty close. The tach's lighting won't be seen but it will be lit by the stock dash illumination so will look similar.
Stu
1967 Mustang Coupe
06-10-2008, 12:20 PM   #4 (permalink)
ewilson2
OR..you can get one from NPD that will fit in the clock opening and match your other gauges
ewilson2 is offline   Reply With Quote
06-10-2008, 05:35 PM   #5 (permalink)
CaptVirgilHilts
Guess I need a new NPD catalog!
Stu
1967 Mustang Coupe
06-12-2008, 09:20 AM   #6 (permalink)
Sponge
I used before the in dash tach from Retrogauge, very nice product! Easy to install and the price is correct.
06-12-2008, 12:58 PM   #7 (permalink)
kechke
Here is an "Autometer" 2 1/16" tach in my clock hole.
http://img.photobucket.com/albums/v2...hke/tach-1.jpg
Non Iiligitimus Carborundum
68 convertable
05 convertable
kechke is offline   Reply With Quote
06-13-2008, 06:33 AM   #8 (permalink)
casadepunklife
the last thing that is is a stupid question. I thought I was stuck with a tach on the column. My coupe is slowly heading toward "sleeper." Mine's an auto, but often shifted manually - I should ditch the big column tach, use one of these mini-tachs and put a separate shift light somewhere.
casadepunklife is offline   Reply With Quote
$3 Tachometer tim1859 The Garage 9 06-19-2005 10:43 PM
flucuating tachometer elsanyo All Ford Techboard 2 11-23-2004 10:47 PM
Looking for a Ribbon Tachometer muffett Torino Pages 0 12-19-2003 04:12 AM
New Tachometer Nastystang The Garage 4 03-15-2003 09:15 AM
Upgrade your Tachometer jcm3 Late Model EFI Techboard 8 03-09-2003 10:47 PM
