06-15-2008, 09:58 AM   #11 (permalink)
BaronVonOttoma
Re: Manual transmission: Clutch cable kit
Originally Posted by Sponge View Post
What kind of clutch do you have? I've a 3 long fingers style and I read that it does require to much effort on the pedal and so, the clutch cable isn't recommended.
Do you agree? Maybe you've a diaphragm clutch style?
Affirmative, switched it to a HD Ford Racing diaphragm clutch. I heard the diaphragm clutch holds better and operates much more smoothly. Any good aftermarket clutch set should work. It definitely feels better than the old z-bar and three-finger arrangement.
BaronVonOttoma is offline   Reply With Quote
06-15-2008, 02:25 PM   #12 (permalink)
Sponge
A 3 finger style does work correctly or does not work at all with a clutch cable kit?
06-16-2008, 09:08 AM   #13 (permalink)
blidzy
What clutch cable and pedal setup did you use Sponge? I am trying to decide on which to get, the cable pull type or the casing push type.
blidzy is offline   Reply With Quote
06-16-2008, 01:25 PM   #14 (permalink)
Sponge
Both clutch cable kits use the same type: pull.
For the pedal setup, I found one on Ebay and I just changed everything on it. The pedal shaft has been installed using a roller kit. With the clutch cable kit, it does not require the big spring over the clutch pedal.
06-17-2008, 08:55 AM   #15 (permalink)
blidzy
I've got the RMP one and it works fine. Kind of funky, the cable end is secured and the clutch pedal moves the cable housing.
Mustang Steve makes a very nice roller bearing pedal cable conversion kit, you might check his site out as well.
This was the cable housing push one I was talking about. Thanks Barron
06-17-2008, 08:58 AM   #16 (permalink)
blidzy
My local classic mustang restorer guy told me to use the z-bar linkage that was original. I have tri-y headers and clearance for a cable is next to impossible without burning a cable.
06-17-2008, 01:18 PM   #17 (permalink)
Sponge
Sorry, my english is not perfect. I apologize.
I thought about protecting full cable with a thermo-protective housing?
06-18-2008, 08:09 AM   #18 (permalink)
blidzy
I thought about that too. Maybe using heat wrap on the headers too. I did that on an old harley I just rebuilt also but I bet it isn't fun wrapping headers, probably be easier to pull them and wrap them.
06-18-2008, 12:35 PM   #19 (permalink)
BaronVonOttoma
Get a hydraulic clutch, you can run the line pretty much anywhere and clear anything. One of these days I'm going to pony up for a hydraulic conversion.
06-18-2008, 06:32 PM   #20 (permalink)
pass1over
I had to run a cable clutch through 2 header primaries. Wrap your headers near where the cable would be, and make a bracket to hold it in a certain position. If you want, Summit or Jegs sells a heat cover that fits nicely around the cable as well.
I found an original style pedal on ebay, used a quadrant and any cable clutch from an 80s mustang, available from any parts house.
'08 Infiniti G37S daily driver
stroked '66 Mustang weekend fun
pass1over is offline   Reply With Quote
Cable clutch PEPPER All Ford Techboard 0 06-30-2006 02:55 PM
T-5 clutch cable mod latamud Falcon Pages 2 02-04-2006 06:45 AM
Changing mechanical linkage clutch pedal to cable clutch sharpshot71 All Ford Techboard 5 02-03-2006 07:28 PM
SB to 460 swap ... Manual Transmission Mustang ... Clutch Linkage Modification MonsterMach The Garage 4 10-20-2005 09:15 AM
adjustable clutch cable dpellegr All Ford Techboard 2 02-09-2002 07:06 PM
