06-12-2008, 10:19 AM   #1 (permalink)
Sponge
Manual transmission: Clutch cable kit
Hi guys,
I already done a research on the forum but I prefer writing on new topic for my question. I've already have late bellhousing and clutch fork in order to install this winter a clutch cable kit.
For you, which product is the best: Ron Morris or Modern Driveline?
I read that Ron Morris kit does use the existing clutch hole in the firewall and Moder Driveline one does require to drill a new hole.
Which one is the easiest to install, does work the best?
Thanks for your help.
Dylan
06-12-2008, 06:53 PM   #2 (permalink)
BaronVonOttoma
Re: Manual transmission: Clutch cable kit
I've got the RMP one and it works fine. Kind of funky, the cable end is secured and the clutch pedal moves the cable housing.
Mustang Steve makes a very nice roller bearing pedal cable conversion kit, you might check his site out as well.
BaronVonOttoma is offline   Reply With Quote
06-13-2008, 06:50 AM   #3 (permalink)
Sponge
The Mustang Steve kit works better? The price is cheaper so was wondering if it's the best clutch cable kit setup?
06-13-2008, 08:42 AM   #4 (permalink)
BaronVonOttoma
I've never used Mustang Steve's kit but I've heard several people rave about it. I think it's a bit more labor intensive (i.e. requires some welding/fab work) than the RMP kit but has more adjustability and leverage built in.
That said, I've had no problems with the Ron Morris kit. Works fine without excessive pedal effort, good feel.
06-13-2008, 09:08 AM   #5 (permalink)
Sponge
What kind of clutch do you have? I've a 3 long fingers style and I read that it does require to much effort on the pedal and so, the clutch cable isn't recommended.
Do you agree? Maybe you've a diaphragm clutch style?
06-14-2008, 07:26 AM   #6 (permalink)
blidzy
Thanks for asking this stuff sponge. I am gathering the parts to do a switch to a T-5 right now and signed on here to ask the same questions. I have a 64.5 Mustang with a 289.
blidzy is offline   Reply With Quote
06-14-2008, 07:45 AM   #7 (permalink)
Sponge
No problem blidzy. It's always a good idea to share experiences.
I made a complete conversion on my ride (automatic trans to manual) so if you've some questions, feel free to ask them on the forum, it's a very good one.
06-14-2008, 09:16 AM   #8 (permalink)
blidzy
I have a T-5 on the way right now. It also includes the bellhousing. Which clutch setup did you go with?
06-14-2008, 11:04 AM   #9 (permalink)
Sponge
A Spec stage II clutch but if you're car has already a manual trans, you probably can keep the clutch. A T5 has 10 splines for input shaft.
06-15-2008, 09:05 AM   #10 (permalink)
blidzy
My car has a C-4 right now so I will need a clutch as well as a block plate for a manual.
Cable clutch PEPPER All Ford Techboard 0 06-30-2006 02:55 PM
T-5 clutch cable mod latamud Falcon Pages 2 02-04-2006 06:45 AM
Changing mechanical linkage clutch pedal to cable clutch sharpshot71 All Ford Techboard 5 02-03-2006 07:28 PM
SB to 460 swap ... Manual Transmission Mustang ... Clutch Linkage Modification MonsterMach The Garage 4 10-20-2005 09:15 AM
adjustable clutch cable dpellegr All Ford Techboard 2 02-09-2002 07:06 PM
