06-15-2008, 08:18 AM   #1 (permalink)
blidzy
289 5 bolt or 6 bolt?
I am doing a tranny swap to a T-5 from a C-4 and the articles I see tell me that early 289's in mustangs were 5 bolt and later changed to 6 bolt. I am not sure if this is the original block so I don't know which it is. I am gathering parts and would like to be able to tell which block plate to purchase. Is there any way to tell which block it is without pulling the tranny? Thanks.
blidzy is offline   Reply With Quote
06-15-2008, 08:50 AM   #2 (permalink)
dennis111
Re: 289 5 bolt or 6 bolt?
Count the # of large headed bolts that pass from the bellhousing into the motor block. That is what the 5 or 6 bolt thing is referring to. Also, another indicator is the diameter of the bolt--if the bellhousing to block bolts have a 5/8" head, you have a 6 bolt block. If smaller, you have a 5 bolt block.
Disregard the starter bolts and the small bolts that retain the inspection plate.
Dennis
11.52@121.29mph
06-15-2008, 03:54 PM   #3 (permalink)
Beoweolf
64 is the year (more or less) that Ford changed over from 5 bolt to 6 bolt blocks. If you know how to read block date codes, that will be a great indication of when the block was cast.
Other than counting bolt holes, thats the best way, cause as I keep mentioning, not all motors are original to the car they came in - people/mechanics, dealers were more concerned with getting car running rather than wasting time looking for an 'exact' replacement engine.
06-15-2008, 06:43 PM   #4 (permalink)
blidzy
You guys rock. Thanks.
06-20-2008, 09:43 AM   #5 (permalink)
blidzy
It was a 6 bolt. Hooray. Thanks again, saved me pulling the thing and then ordering parts.
1964 1/2 D code Mustang convertible.
Bellhousings: early 5 bolt vs. 6 bolt 3ondatree Falcon Pages 8 01-31-2008 05:40 PM
What year did Ford switch from 3 bolt to 4 bolt crank balancers? Frank Mustang Pages (1965-1973) 6 10-31-2006 07:00 PM
What year did Ford switch from 3 bolt to 4 bolt crank balancers? Frank Truck Forum 2 10-27-2006 09:12 AM
Bolt size to bolt motor to engine stand? Brian M All Ford Techboard 5 05-31-2005 05:42 PM
351C 2 bolt to 4 bolt conversion MonsterMach All Ford Techboard 3 04-23-2002 08:52 AM
Lakewood
