Re: quick carb help autolite 2100
As per picture above. I also found there to be two types of fule inlets. Those with and without an external filter.
The fuel line originates and gets connected to the fuel pump. Then goes up to the carby, and ends in either a fitting or end of tube. The raw tube type has a short rubber hose to attach on to the filter end. The fitting style goes direct into the inlet of the carby and snuggs up there.
The whole carb is a bit simple, and only leaks out the bottom at the power valve or the end at the acellerator pump.
Wm.
Old Ford owner
