Need suggestions for 289 smoking issues
Hey, I'm new to this site here after meeting an active member at a car show at Yearone. I've got a problem that I can use some help on...
I had two oil breather caps, one on each valve cover. I was driving back from a show and smoke was coming into my vehicle through the firewall and was coming out of the breathers on the engine. I pulled over checked it out, continued on my 30 mile journey home with some smoke coming in, temp gauge normal, oil pressure around 60. After bringing the car to a shop to have some gauges installed, the mechanic said I didn't have a PCV system installed so he did it, running the PCV and hose from the passenger side cover to the carb which should create the cyphening (sp?) effect to reduce the smoke.
Drove it yesterday and again was getting some smoke in the car. (Not a ton, but smoke non the less) Went to NAPA and the old timer (who has been racing here in GA for a long time knows a lot) told me to try to shake the PCV and if it rattles, it's no clogged so it wouldn't be that. (Tested at home and wasn't that) And he also suggested cover cap so that there is no breather on the cover so I went back out and got one. Just tried it, and oil starting spewing out of my dip stick. What's up with this??? I put the breather back on and let it idle for a couple minutes w/o the oil spitting out. There's no sludge in the covers b/c I changed the gaskets recently after the initial smoke situation.
He said I may have a cracked piston ring too and oil is burning which is a possibility. With my symptoms above, does anyone have a good diagnosis? Has this happened to anyone before too? I have had this car for a year without any issues of smoking.
