Re: 72 brake help!
I agree that the piston looks to be protruding. IIRC, the piston should be nearly flush with the surface of the caliper. In the 2nd pic, it also looks like the outer pad is not seated correctly on the caliper.
FWIW, pick up a pair of rebuilt calipers from an auto parts store and check to see if they will fit. My guess is someone used the wrong piston on the ones you have....
One more thing, make sure that the bleeders point to the rear of the car when installed. If they point straight up, you need to swap them side to side, as will never be able to fully bleed them.
...nothing worthwhile is ever easy....
71 Mach 1
69 Mustang coupe
