Re: Thermostat
All you gotta do is lay that chrome POS on a piece of 80 GRIT sand paper on a flat smooth surface, and slowly flatten it. Slide it back and forth until all the surface scratches are the same depth and go in the same direction then swirl it in a circle and check for any spot the cirrcular marks might have missed , if there are none then you are done.
Don't over tighten.
Don't waste time with smaller grit than 80G, it's just time consuming, the 80G marks will never cause a leak.
If you want to use a rubber O Ring, then you will NOT need a gasket, and the housing you bought will need to be machined for an O ring. Also, try to stay away from using more than the thinnest film of sillicone that you can make. Any thicker and you are only wsting it.
Hope that helps.
FE
