07-05-2008, 07:42 PM   #1 (permalink)
blidzy
Neutral safety lockout bypass
I am installing a T5 in place of a C4 and need to know what to do to bypass/replace or rewire the neutral safety switch. Also, are there any other electrical connections I need to know about? Thanks.
1964 1/2 D code Mustang convertible.
blidzy is offline   Reply With Quote
07-06-2008, 08:24 AM   #2 (permalink)
CaptVirgilHilts
Re: Neutral safety lockout bypass
The NSS is on the transmission selector lever on the transmission. There should be four wires. Two will be red with a blue stripe. These are the two that need to be connected together. They interrupt the connection to the starter relay when the car is not in park or neutral. The other two wires are the reverse lights ( if your 64 1/2 was equipped). They can be connected to the T-5's reverse light switch.
Stu
1967 Mustang Coupe
07-06-2008, 12:14 PM   #3 (permalink)
blidzy
Thanks! You made my life easy.
can i bypass Neutral Safety Switch?? MauriSSio Galaxie Pages 29 10-09-2008 05:04 PM
Neutral safety bindirdundat Fairlane Pages 3 05-18-2007 05:39 PM
neutral safety switch 69fstbk All Ford Techboard 8 02-21-2005 05:50 PM
neutral saftey swith t5 93 bypass? or wiring diagram? rock5757 Late Model EFI Techboard 0 03-14-2003 08:47 PM
Neutral Safety bypass backdft21 All Ford Techboard 0 05-20-2002 12:41 AM
