07-07-2008, 12:04 PM   #1 (permalink)
rmestep
Question 66 belt issues
I have a 66 coupe with a 73 302 block, 65 289 heads. I am looking for a way to get v belts to work on it. I am wanting to use the 66 water pump {brand new never seen coolant yet}. and the 73 302 harmonic balancer. I have tried to use 2 different complete sets of pulleys off a 302, seen elsewhere in this forum, and have the same problem. The water pump pulley hits the crank pulley. This is frustrating because now the questions start to run through my mind, is the 289 pump closer to the crank? How can I still use the v belt system? by the way I am only running an alt., and water pump.
rmestep is offline   Reply With Quote
07-07-2008, 01:38 PM   #2 (permalink)
beegshot
I just went through the exact same thing...
I ended up taking my brand new four bolt harmonic balancer off and putting one of my old 3-bolt balancers on. Fortunately, I had three different sets of pulleys/belts laying around and was able to put the whole set-up together with what I had. I have a Power Steering pump, so I needed a two groove pump pulley. Do you have a set of pulleys for a 289? They should work with the set-up you are using.
***The root cause of your problem is going from a water pump with a Driver Side inlet to a water pump with a Passenger side inlet. ***
That 73 motor had a D/S inlet, didn't it? The shaft on the D/S inlet pump is not as close to the crank shaft as the P/S inlet pump. That's why your pump pulley hit the harmonic balancer when you tried to use the D/S inlet pump pulley on the P/S inlet pump.
Robert
http://www.fordmuscle.com/pics/beegshot_a.jpg
Beegshot
2 - 65 'stangs, 79 F100 SuperCab, 03 Expedition
Henry Ford said, "If you find you need a tool, you have already paid for it."
Last edited by beegshot : 07-07-2008 at 01:41 PM. Reason: clarified a technical comment
Serpentine Belt Or V Belt ? MCCUTCHEON4 All Ford Techboard 2 03-07-2008 07:56 PM
Short belt for 5.0 brokenc6 All Ford Techboard 2 06-25-2006 06:08 PM
Run with no belt? 89Trooper All Ford Techboard 11 03-27-2005 09:11 PM
Threw da belt.... deleted3 All Ford Techboard 5 03-14-2005 09:13 PM
Can i disconnect the AC belt? HammerDown All Ford Techboard 2 12-26-2003 07:01 PM
