07-09-2008, 09:20 AM   #1 (permalink)
Roarnracin
Cool T-5 Conversion Clutch Set 68 Mustang
I am converting my 1968 Mustang Convertible from an automatic to a T-5. I am using the 28oz flywheel. Does anyone know which clutch set to use?? Or do I have to buy the separate pieces? Is the clutch disc different for the T-5?
Thanks,
Rob
Oh My Lanta!!!
Roarnracin is offline   Reply With Quote
07-11-2008, 06:06 AM   #2 (permalink)
blidzy
Re: T-5 Conversion Clutch Set 68 Mustang
You have to use the year correct clutch for your motor. The late model pressure plate wont bolt up to the flywheel. I just went through all this. I had a late model clutch and it was a no go. Both early and late model clutches are ten spline so the shaft will fit either. As far as what the part number is, there are quiet a few that are made for your year, from mild to wild. Auto zone can get you a normal clutch for about $110. If you want performance clutch, expect to pay about $300-400.
Here are some that will work.
AutoZone.com | Vehicle Selection - Year
1964 1/2 D code Mustang convertible.
blidzy is offline   Reply With Quote
07-11-2008, 04:15 PM   #3 (permalink)
ujt389
You can also get a new flywheel with the correct 28 oz. balance that accepts both the early and late model style clutches. That is what I used on my early motor with the latemodel t-5 cnversion.
07-11-2008, 09:04 PM   #4 (permalink)
blidzy
Got a source? There are a lot better clutch options with the late models than the early.
07-12-2008, 03:33 AM   #5 (permalink)
ujt389
It was a while ago when I got mine, but Im pretty sure it was from ford racing. It was a billet steel piece that was SFI approved. You should be able to get a simular flywheel from Mcleod, ram, or any other clutch maker.
07-12-2008, 11:46 AM   #6 (permalink)
Gydyup
Mcleod makes em both tooth rings, both ballance options, with bolt patterns to accept both pres plates - just be sure to use the dowel pins if you go to the diaphragm clutch.
If you need a PN I can dig it out for you, I run the cable on my toploader with the diaphragm clutch.
Gydyup - 67 Mustang Coupe
\"old School\"
07-12-2008, 12:03 PM   #7 (permalink)
Jetfixr320
Hey Roarnracin,
Sent you a PM about darkhorse. Wanted to see if you can help me get a crossmember for my 64 Fairlane.
Email me @ SLoweryIN@comcast.net please.
I can't get him to follow through after my phone calls to him.
Wanted to see if you could pick one up for me or send pics and dimensions of the crossmember?
Thanks,
Steve
Jetfixr320 is offline   Reply With Quote
07-16-2008, 03:32 PM   #8 (permalink)
66 RestoMod
Our 289 and t5 are using a 28oz Zoom Performance Flywheel and late model clutch.
It comes with bolt on weights for 28 or 50 oz imbalance.
you must use a 5.0 starter.
It was a little pricey...
66 RestoMod is offline   Reply With Quote
07-17-2008, 12:46 PM   #9 (permalink)
Roarnracin
I never got a hold of him either....I don't know what his deal is??
Oh My Lanta!!!
07-17-2008, 12:47 PM   #10 (permalink)
Roarnracin
Talking Re: T-5 Conversion Clutch Set 68 Mustang
Thanks for all of the ideas and help!
Oh My Lanta!!!
clutch cable conversion dragula63 Mustang Pages (1965-1973) 7 02-15-2008 07:40 AM
HYD CLUTCH CONVERSION RECOMENDATIONS. quickshift All Ford Techboard 1 03-02-2007 09:39 PM
Clutch conversion Krazykrenz Galaxie Pages 0 09-21-2005 10:59 AM
cable clutch conversion NoLongerHere2 All Ford Techboard 0 05-24-2005 12:32 AM
Which Clutch Cable Conversion To Use??? GregS All Ford Techboard 6 03-15-2004 09:27 PM
