07-12-2008, 10:53 AM   #1 (permalink)
Gydyup
67 Mustang Steering Column Bracket
Here is my head scratcher, some time ago I swapped out my clutch/brake support bracket with roller brngs etc for the cable clutch.
I snugged down the studs into column support/brake clutch bracket. Worked great, but after driving I noticed a little play in the column so I snugged em some more and the nut inside the brake/clutch support bracket starts spinning inside the assembly. Cant tighten, cant loosen!
I have another brake/clutch bracket, but really dont want to pull it out again now, I will do that when I strip the car for painting etc later.
Anyone got a quick fix or way to remove/replace the threaded stud/nut - again, not looking to replace that whole thing right now.
Gydyup - 67 Mustang Coupe
\"old School\"
07-12-2008, 01:02 PM   #2 (permalink)
CaptVirgilHilts
Re: 67 Mustang Steering Column Bracket
If you remove the gauge cluster you can get access to the top of the "cage" that the nut is held in by. I would then try to jam the nut with a large flat bladed screwdriver or similar. OR if a bit of the stud is showing clamp a vice grip on the end and tighten/loosen as desired. My cluster is out on my '67 so I had a look and it is quite easy to access it.
Stu
1967 Mustang Coupe
07-13-2008, 06:39 AM   #3 (permalink)
Gydyup
Thanks, I can see the stud end, but the whole mess is turning inside the cage assmbly.
The guage cluster route sounds like a good way to go, thanks Capt.
Gydyup
\"old School\"
WTT;1973 Mustang 4 sp steering column for automatic oldfarte Wanted 1 05-10-2008 04:29 PM
Mustang Power Steering Lowering Bracket mntmotorrider Parts for Sale 0 10-27-2007 03:18 PM
Steering Column jhovis Galaxie Pages 0 03-16-2007 07:28 PM
70 mustang, cougar steering column Quid All Ford Techboard 2 07-02-2003 01:37 PM
Help with 65 Mustang steering column wiring. oldmustangjunkie All Ford Techboard 0 10-16-2002 03:12 AM
