07-14-2008, 10:11 PM   #1 (permalink)
428cjmaverick
Motor swap questions
I have a buddy with a 67 stang that has a 6cyl. in it and he got a 302 from a 89 lincoln towncar and wants me to swap the motors.I've got some questions
I know i need new motor mounts.
I dont know about the oil pan does it have to be a front sump or what?
We're switching it from F.I. to carbed so i know i'll need a new intake and a carb.
Will the trans from the lincoln work or no?
And anyother help would be great thanks.
Maverick
428cjmaverick is offline   Reply With Quote
07-15-2008, 08:25 AM   #2 (permalink)
beegshot
Hmmmm, I'll take a shot...
Mav,
First off, you can swap out the engine and tranny on that car with the Lincoln hardware. You'll need to get some '68 V8 motor mounts. Does that tranny have a link to the computer? How about the speedo drive...is it mechanical?
But, you shouldn't just swap out the engine and tranny on that 6 cyl. car without changing the front suspension and the rear-end. Which means you'll need four new wheels (to replace the 4-lug wheels currently on the car). I just did a 65 Mustang 6 cyl-to-V8 swap. It took 6 weeks (including paint work in the engine compartment) to complete.
Give us some more information. What other mods does your friend have planned?
Robert
http://www.fordmuscle.com/pics/beegshot_a.jpg
Beegshot
2 - 65 'stangs, 79 F100 SuperCab, 03 Expedition
Henry Ford said, "If you find you need a tool, you have already paid for it."
07-15-2008, 03:41 PM   #3 (permalink)
Hemikiller
Re: Motor swap questions
In addition to the new intake and carb, you'll need a distributor that will work with your ignition of choice, a front sump oil pan/pickup and a set of the V-8 insulators & mounts. You'll also need a timing cover, brackets and pulleys if you want to use the '68 style front dress and/or a mechanical fuel pump.
The 89 AOD is a standalone unit, but you'll need a Lokar TV cable setup for it to operate properly. Be sure to grab the plug from the Lincoln for the neutral safety/backup lights harness.
...nothing worthwhile is ever easy....
71 Mach 1
69 Mustang coupe
Hemikiller is offline   Reply With Quote
ENGINE/MOTOR Questions... FEandGoingBroke All Ford Techboard 23 04-24-2008 03:45 PM
2 questions about a stroker motor? greasemonkey85 All Ford Techboard 0 01-30-2007 02:27 PM
new used motor questions casadepunklife All Ford Techboard 8 12-15-2006 12:46 PM
Motor swap questions + other stuff. CruisinRT66 Fairlane Pages 2 08-26-2006 08:44 PM
5.0 swap into ranger, motor build questions mas942 All Ford Techboard 4 02-13-2005 12:11 AM
