09-04-2008, 06:43 PM   #1 (permalink)
68-408
Question 1970 Galaxie 9 into 68 Mustang
I found a 70 Galaxie with a 390 c6 and a 9" rear. The guy wants 500 for the car. How difficult would it be to do this swap? And would it be worth it or should I just buy a Currie. I am not much into sitting on things until it sells; so I would junk the rest of the car.
68-408 is offline   Reply With Quote
09-05-2008, 01:48 AM   #2 (permalink)
PaulS1950
Re: 1970 Galaxie 9 into 68 Mustang
If it all runs and drives it is well worth it. If it isn't running then you may end up with so much junk.
Paul
09-05-2008, 03:55 AM   #3 (permalink)
frdnut
Re: 1970 Galaxy 9 into 68 Mustang
If you were planning to swap the whole thing I am pretty sure it is way to wide to fit in a mustang.I think it is also set up for a coil spring suspension so you would have to weld on the spring perches.Way too much trouble in my opinion...Look for 69-70 mustangs and cougars for a housing that will bolt right in..
09-05-2008, 07:44 AM   #4 (permalink)
forthman
The 390 should bolt into the engine bay. Springs might need to be changed.
I think the C6 will bolt in also.
When I was 16 the fastest car I drove was a 390 Mustang fastback.
It had an automatic.
Gotta figure being 38 yrs old the engine will need some work.
Also do not think the valve seats will be hardened. So they might be worn pretty good.
The C6 will be easy enough to rebuild.
1966 Stang Coupe Org. 6 cyl. 351w,Sealed Power Hypers, ARP bolts,Total Seal rings,Eagle H-beams rods,Balanced,Hedman long tubes, Pro Comp 2.05/1.60 Heads, Shaft roller Rockers, Victor Jr intake, Holley 750 DP, Ed Nix Custom .600/.600 254/258 @.050 Solid Cam, Crane solid roller lifters,Richmond 4.11, Strange mini spool, Modified C4, 3500 stall, Redneck Transbrake, B&M Hammer shifter, Shelby lowered, Pro Comp 6Al system. Mickey Thompson 275/50 Et Street Drag radials.
1970 mustang 4 speed console 2manyoldcars! Wanted 0 06-14-2008 10:01 PM
1970 Mustang Fastback raremuscle Vehicles for Sale 2 04-03-2008 12:31 PM
1970 302 heads on 1990 5.0 Mustang 65bird All Ford Techboard 4 10-13-2004 02:59 PM
1970 mustang coupe pink67 All Ford Techboard 1 10-31-2002 12:26 AM
How big of an Alternator can I put into my 1970 Mustang... tmatthews All Ford Techboard 5 02-19-2002 06:56 PM
