09-05-2008, 11:48 AM   #1 (permalink)
markw
wiring a 12v 6a stereo amp to ign accessory
ive just bought one of these..
http://cgi.ebay.co.uk/Car-Motor-Bike...d=p3286.c0.m14
i`m not hugely worried about power and excellent sound quality and this seemed cheap and small.. the plan is to get an old dead `68 radio and retrofit this inside and wire up the appropriate pots.. i dont listen to the radio or cd`s so i`ll just use it as an mp3 input
plus, if i screw it up.. it didnt cost much..
the question is.. this amp takes 12v 6amps, i`m wondering what amperage is supplied to the accessory switch. (i have a free black and green cable which has power, i thought i could use that, with a fuse of course) or maybe theres a pre fused accessory lead i can use.. car isnt here so i cant check.
as an aside, will any pre `69 radio fit in a 68 dash and bezel? (if so does anyone have a dead one they dont want?)
ta,
Mark
markw is offline   Reply With Quote
09-06-2008, 09:39 AM   #2 (permalink)
rkingston
Re: wiring a 12v 6a stereo amp to ign accessory
Looking at the power jack in the picture, you should be okay. Just wire it into an available circuit and check your fuse box for an appropriate size fuse. If you're worried about it you can install a 5 pin relay and use the ignition switch to energize the relay and use battery power for the amp. I don't think this is necessary though in your case. Should work fine, even on the other side of the pond.
65 Mustang 289 - Forged Pistons RPM Air Gap 650DP AOD Tranny 9 inch trac-lock w/ 3.50 gears Solid Lift Cam Hooker Headers MSD Ignition Sub Frame Connectors
rkingston is offline   Reply With Quote
Need stereo wiring help in Mustang 08 LtcdData All Ford Techboard 2 03-29-2008 08:56 AM
accessory Sun tach gobe Galaxie Pages 1 08-24-2006 07:09 PM
More Oil Accessory Problems Havastang65408 Stroker Engines 0 07-28-2006 02:46 PM
Accessory Wiring Question thecougarguy All Ford Techboard 3 07-13-2002 04:43 PM
anybody know any good car stereo forums? a forum just like this one but in car stereo? XolieX All Ford Techboard 5 06-04-2002 02:08 AM
