09-07-2008, 11:59 PM   #1 (permalink)
falcon501
69 brake booster
I have a bad power brake booster in a 1969 Mach 1 CJ . I can't find any factory replacments only a place to send mine in to be rebuilt. Do most people just go with an aftermarket or who should i send mine in to have it rebuilt, or can i buy one and from what vendor ?
Just so i'm testing it right I hooked a vacuum gauge and it would not pull any vacuum. Changed the master cylinder still no peddle and won't stop very good.
Thanks any help appreciated
tracy
falcon501 is offline   Reply With Quote
09-08-2008, 08:52 AM   #2 (permalink)
coosbaylumber
Re: 69 brake booster
I had similar problem with my 1970. It worked, but not good. More problems with the actual master cylinder fitting the assigned location.
Was told this item was still in stock at and Ford agency, and that was bumm information. I found the guy in Kentucky advertising parts, but gone when he got my order about one week later. Then found someone in Eastern time zone, he did not sell parts, but instead rebuilt them. I sent it there then. Is now hissing again, after three years of use.
Wm.
Old Ford owner
09-08-2008, 11:38 AM   #3 (permalink)
Hemikiller
Advance has Cardone remans for under $100...
Bendix style
Midland (band clamp) style
FWIW, if you have no pedal, then it's probably air in the lines, not the booster. A bad booster normally will give you a rock hard pedal.
Did you bench bleed the new master before installation? Have you bled the lines completely? Are the rear brakes adjusted up 'til there is a slight drag on the drums? Are your calipers on the correct sides (bleeders pointing toward rear of car)?.......
...nothing worthwhile is ever easy....
71 Mach 1
69 Mustang coupe
Hemikiller is offline   Reply With Quote
09-08-2008, 06:03 PM   #4 (permalink)
falcon501
Thanks Just called them and they are ordering !!
09-10-2008, 07:57 PM   #5 (permalink)
Grabber70Mach
Never used this company, but have heard good about him.
Booster Dewey Power Brake Booster Exchange Inc.
Grabber70Mach is offline   Reply With Quote
09-11-2008, 06:04 AM   #6 (permalink)
chockostang
We carry Newly Rebuilt, and NEW SSBC Factory Style Bendix Boosters for all 67 68 69 70 Mustangs.
Also for 71, 72, and 73 Mustangs.
217 882 2083
CHOCKOSTANGCLASSICMUSTANG.COM
chockostang is offline   Reply With Quote
09-11-2008, 06:07 AM   #7 (permalink)
chockostang
[quote=chockostang;1440575]We carry Newly Rebuilt, and NEW SSBC Factory Style Bendix Boosters for all 67 68 69 70 Mustangs.
217 882 2083
Brake Booster coolreed Mustang Pages (1979-1995) 0 08-07-2007 12:01 PM
Brake booster for my 390 HammerMechanic Torino Pages 4 09-19-2005 01:12 PM
PCV & Brake Booster JAhrens All Ford Techboard 1 04-10-2004 12:24 PM
Another brake booster Q... deleted3 Galaxie Pages 1 09-01-2002 12:09 PM
Brake Booster 63fstbk Galaxie Pages 0 08-31-2002 08:54 PM
