Hey guys, I know this thread is similar to one (or more?) of the other threads, but I have some interesting circumstances, and I was hoping to get some advice on them. Okay, so I'm running a 351W in a 65' coupe, the radiator currently in it is not cooling well enough, it is the stock copper/brass one that came with the 289, and tho it doesn't leak it shows it's age.
The engine itself isn't exactly stock, i'm running an Edelbrock Hi-po air intake, Edelbrock hi output 4v, a performance air filter (I can't remember off the top of my head the brand, but it's not a Fram) w/ hood scoop. Also, I have power steering, however much difference that would make. I am finishing up rebuilding the top end this week, and the entire engine was rebuilt maybe 7 years ago (only 10,000 miles ago or so), so it should be running pretty clean.
The biggest variable that I can't really predict here(and have gotten lots of different opinions on) is my radiator fan. The guy before me (obviously having the same cooling problems) put in an aftermarket radiator fan. It is a non-electric, 6bladed fan (blades are 4' wide). I do not, however, have a radiator shroud. I have had some stock purists tell me that I need to swap it back to stock to get the shroud, but I am not confident that it will help the problem. Opinions? So yea, I am thinking that the best solution is to leave the fan be and get a new radiator. I am not sure where I should go with this...part of me wants to believe that the problem lies mostly with its' age, and just swapping in a new one would fix everything, but I would not be happy about drooping $200 just to be proven wrong.
(third one down)
Mustang Parts House
Or I could go with the generic aluminum radiator and run the risk of not being able to figure out how to get it in. I am reasonably creative at such things, but do not have an overwhelming amount of metalwork experience, so i'm not sure on this one.
www.pitstopusa.com - Detail
(And are there different ones like this that you would reccomend???)
Finally, I could drop the major change and go for the correctly fitted aluminum one. I found two, which the major difference between the two that I found was $130, I would appreciate if any of you guys have any input on difference.
(The $300 variety)
Mustangs Unlimited - The Premier Source for Mustang, Shelby and Cougar Parts and Accessories
(The $430 variety)
(PS, all of these are within my means to acquire, but it would delay other pony projects for financial reasons if I were to drop $430 for a radiator...)
Any input you guys have would be greatly appreciated. I wish I could give you a hp approximate for the engine, but I really don't know...i would guess somewhere in the ballpark of 300? If anyone cared to guess on that I'd love to know what you think (given the limited info that I have...no idea on piston brand and the like) Thanks!
