does anyone know if the rocker stud holes in a 302 head are vertical (perpendicular to the base)? as in, if you were to place the heads flat on a drill press type device, would the drill enter the hole square.. i`m just wondering if its possible to thread the holes at home with something like this :-
http://www.murphyauctions.net/images/synergy/21.jpg
i cant find any with tilt tables that would be necessary if the holes arent vertical when the head is laid flat.
