03-25-2006, 05:14 PM   #1 (permalink)
gnnormand
351w in 76 mustang II
who makes headers,motor mounts and what oil pan. also need to know if the 76 C4 has the same bolt pattern as my 89 351W. Greg
gnnormand is offline   Reply With Quote
03-26-2006, 04:08 AM   #2 (permalink)
tonys10sec306
check with hooker for headers
03-26-2006, 05:18 AM   #3 (permalink)
5851a
Mustang II flywheel, bellhousing, block plate, and oil pan are all matched to fit together. The 302 oil pan was smaller at the back to make room for the starter because of the smaller flywheel. Bellhousing, plate, and flywheel will bolt onto the 351. I would try a front sump 351 pan and a small diameter starter. I would try it with the engine out first.
04-13-2006, 11:33 AM   #4 (permalink)
dfree383
I used a milodon front sump pan on a 351C swap years ago. Had to notch the sump for rack and pinion clearance.
