Re: 1973 Cougar xr7 351C engine in a FOX.
Several options, tubar crossmember and A-arms with coil over springs will reduce weight and give you a better spring rate. Bigger front swaybar a must. Or factory V-8 springs, with bigger swaybar and then get the GT, Cobra or whatever bigger disc brakes for the front. If you have a stick shift trans already, get a hyd throwout bearing setup for the new clutch, otherwise and auto is your easier route. Assessories will be your biggest PITA, due to the other engine mounts. Motor mounts, make your own or kits available, just a matter of $$$$ you want to spend.
Lead, Follow, or get the F%$K out of my way.
