11-11-2008, 09:28 AM   #1 (permalink)
RagTop
Mustang II axle swap
I want to convert to 5 lug axles on my 1976 Cobra II . Does anyone know of any axles that are a direct bolt on swap into the II housing? Any help or information on this swap is greatly appreciated.
_____Dare to Differ: STAY INLINE_______
1966 Mustang Convertible, Candy Apple Red, Black Interior with Black power top, 200 CID I6, Autolite 1100, C4 automatic trans.
RagTop is offline   Reply With Quote
11-15-2008, 05:33 AM   #2 (permalink)
5851a
Re: Mustang II axle swap
I have the axles from a maverick in my 77. Not done with the project and don't have the brake drums for it yet. If I remember correctly I had to use the Mustang bearing retainer so it would bolt to the axle housing and open up the center slightly so it wouldn't rub on the axle. Both rears were 8". I was thinking the early Ranger brake drums would work but haven't got that far.
11-15-2008, 08:08 AM   #3 (permalink)
welder4956
I'm using 76 Granada axles with the Mustang II retainers.
Accu Auto Parts - Parts Detail Page
welder4956 is offline   Reply With Quote
11-23-2008, 01:56 AM   #4 (permalink)
RagTop
Question Re: Mustang II axle swap
Did you purchase you axles from Accu Auto? Were the Granada axles a bolt on swap or did you have to make any modification? What did you do to change the front to 5 lug? Thanks for any and all information on the project from you and 5851a. Need all the help and input that I can get.
11-23-2008, 08:16 PM   #5 (permalink)
welder4956
I purchased the axles from Accu Auto. They must be trimmed to match the length of the existing axles, otherwise they bolt right using the old Mustang II retainers and new bearings. I trimmed the length using my abrasive chop saw ground a chamfer on the end with my bench grinder, then cleaned them up with a flat file. If you find used Granada axles, they are the correct length and will not need to be shortened.
Rear drums are for a 1983 Ford Ranger pickup:
NAPAONLINE®
The front is 5-lug 11" Granada rotors with GM calipers and a bracket kit. This is the same as the kit I have:
eBay Motors: MUSTANG II CALIPERS & BRACKETS 11" BIG BRAKE CONVERSION (item 170275107415 end time Nov-27-08 22:48:04 PST)
Have not installed these yet. I still need to order the front hoses.
I used this as a guide:
Them's the brakes! - Mustang Forums at StangNet
11-25-2008, 03:49 AM   #6 (permalink)
RagTop
Thanks for the information. Very helpful, but did you have to change any of the rear brake hardware, shoes, backplate, or anything else when using the Ranger rear drums? Thanks again for the info and help.
11-25-2008, 05:41 AM   #7 (permalink)
5851a
I cheaped out and just bought the 5 bolt rotors from speedway, same size as the original.
rea axle swap 67mustangcoupe289 Mustang Pages (1965-1973) 5 05-29-2007 08:45 PM
9" Axle swap on 1989 Fox Mustang 67fastback All Ford Techboard 10 08-16-2005 08:17 PM
Swap 8.8 rear axle for 9 inch! 9” Brakes to use? What about stock 5.0 mustang brakes? 67fastback Late Model EFI Techboard 2 08-12-2005 10:37 AM
8.8 axle swap mac351c Late Model EFI Techboard 1 09-18-2004 01:05 PM
8in.axle swap 64 TBOLT All Ford Techboard 13 03-18-2002 05:53 PM
