08-12-2005, 08:23 PM   #1 (permalink)
acidflux
460 roller cam conversion help
Hi, im new to the forums so bare with me.
Im building a 460 pretty solid i think but i have a question regarding my cam bearings. I have a list of mods/parts too long to list at my website (hardly any pics though).
www.acidflux.com/setup.html
Ok now for the main point. I have a whole set of clevite 77 bearings for my engine. I decided that i wanted a hydraulic roller cam. i called schneider racing cams (crowers ex partner) and got a roller cam kit for my engine consisting of a billet cam, and some good springs/locks/retainers and a set of Crane roller lifters. The BIG question is, do i need roller cam bearings for my engine, or will the clevite 77s work? i guess i should ask schneider racing cams but i would rather have input from the crowd. also, would a roller cam retainer plate/cam button be useable or adviseable. ive heard of cam walk with roller cams and thats the last thing i want after spending so much on my engine.
also, tell me what you guys think of my setup so far from my website. im in the process of building the motor as we speak and its ready to have the bearings put in but before i do it, i wanna be extra sure that im not gonna cause prematuree bearing failure due to wrong bearing/cam mix.
fyi, this is being stuffed into a 1983 mustang gt. all i can do is beg for mercy from the traction gods because my entire suspension in the rear is stock with the exception of subframe connectors and some kyb gr2 struts. gotta save up for ladder bars or a 4 link. i already have a narrowed 9\" that i need to put in. man....so much work ahead of me. why did i start this project.
any suggestions?? thanks
nelson
acidflux is offline   Reply With Quote
09-15-2005, 02:42 AM   #2 (permalink)
ccso640
Roller cam bearings are really only needed if you have extreme valve spring pressure needed with a cam of .750 lift or more. Yea, good luck with traction, can fit a 28-10.50 under there which is what I have. My 532 with a powerglide and 8 inch converter has a best 60' of 1.38 leaving at 5800 on the brake. Good Luck!
ccso640 is offline   Reply With Quote
09-28-2005, 09:11 PM   #3 (permalink)
mavman
yes, those roller cam bearings are expensive, noisy, and they ain't exactly easy to install. They do free up a little power though. Use your Clevites...they'll be fine.
I'd be more worried about that POS 7.5" rear than anything else. I can't count on one hand how many I've broken...behind everything from stock 5.0/AOD to a 4 cylinder car/T5. The cone-type posi small spiders are the weak link.
Big block in a "light" mustang....sounds like a ton of fun!!
Powerhouse products
