09-13-2005, 07:04 PM   #1 (permalink)
aleborjas
cold air intake
hi
wich cold air intake you think is the best because i whant to change my wimpy reactive gettin hot air from the engine i think about buying the AFM(andersonfordmotorsport) what you say because the AFM is pricy![img]/phpBB/images/smiles/icon_confused.gif[/img][img]/phpBB/images/smiles/icon_mad.gif[/img]
aleborjas is offline   Reply With Quote
10-01-2005, 10:07 PM   #2 (permalink)
Ronbuell
cold air intake
I built my own with stuff from Lowe's. Removed stock airbox and put on cone filter. Got aluminum flex tubing and ran that under the passenger fog light, used a large dust pan upside down and shaved for air scoop and pop rivited it up. Ran the flex hose up thru fender thru hole inside next to the cone filter. Then used a short section of stove pipe on the engine side of the filter to trap the cooler air and prevent turbulence from the fan from messing with the MAF. I get a lot of good comments when I go get my oil changed. The guys nod when I tell them I did for $30 and about 2 hours time. The good news: Gas mileage up to 24, Trapped 1/8 mile, 9.36 @75. Only other mods are GT40 intake, 65mm TB, and 73mm C&L MAF and O/R pipe.
10-03-2005, 05:33 PM   #3 (permalink)
173speed
cold air intake
i use the mac could air intake i think it work good and when i go to the track i just take the ride side light off i have another light that i cut the lens of put that on run some flex pipe from the intake to the back of the ligh and there u go ram air it works good ...
173speed is offline   Reply With Quote
