03-04-2006, 06:42 PM   #1 (permalink)
1992lx50
having a little problem need help
i just recently put in a 75 mm mass air with 24 pound injectors on my 5.0 and since than ive had a problem with it studdaring and it pings a lil but not all the time, it will run great for a while and run like **** out of no where, i have alot of crankcase pressure could this be my problem or should i keep looing
i also have cobra upper and lower a crane came and 70mm throttle body for more air can someone help me?
1992lx50 is offline   Reply With Quote
03-04-2006, 07:18 PM   #2 (permalink)
whitefifty
check your tps reading it should be .94-.99 volts or something like that,also you didn't mention having a adjustable fuel pressure regulator maybe your fuel pressure might be wrong.It should be about 40 psi.
whitefifty is offline   Reply With Quote
03-05-2006, 11:20 AM   #3 (permalink)
1992lx50
ok thanx ill check the tps and i have a stock fuel regulator also i called a performance shop and they said it could have something to do with my pcv valve cud this be possible
03-10-2006, 06:25 AM   #4 (permalink)
FFR65MKIII
Did you recalibrate your computer? Just a thought.
FFR65MKIII is offline   Reply With Quote
Probe Industries
