03-08-2006, 09:16 AM   #1 (permalink)
coolreed
Harmonic Balancers and Flywheels
I am building up a 331 stroker for my Mustang. I am thinking about utilizing the Scat 9000 crank, forged pistons from probe so they will accomadate my TFS twisted wedge heads and forged I beam rods. What is the best Harmonic Balancer to use now? And I wanted to utilize a aluminum flywheel. What brand flywheel should I use?
Any suggestions a good dealer to purchase the parts from including the stroker rotation assembly? [img]/forums/images/smiles/icon_smile.gif[/img]
coolreed is offline   Reply With Quote
03-08-2006, 03:56 PM   #2 (permalink)
Bluemr24
When stroking to a 331, you must use a 28 oz. inbalance balancer and flywheel, or you could ruin the whole thing.
I have done this three times using carb and EFI.
Reply if you need more help.
Mike
Bluemr24 is offline   Reply With Quote
03-08-2006, 04:04 PM   #3 (permalink)
coolreed
Thanks for the reply. However, that was not what I was asking. I was needing some advice on what 'brand' of harmonic balancer or aluminum flywheel to use.
I have heard you need to be very careful with regard to harmonic balancers. ' Fluid Dampner' sounds like a good unit but I have never used one.
HELP!
03-08-2006, 09:43 PM   #4 (permalink)
Magic
as long as its SFI approved you should be ok...
TCI, FulidDamper, CAT etc....either a steel one or a "fluid" one will be good, dont get one with the rubber in between...
make sure u get the proper damper, with regards to the "height" etc and the correct hub and bolt pattern for the pulley....
Magic is offline   Reply With Quote
03-12-2006, 07:05 PM   #5 (permalink)
tonys10sec306
i am with magic and sfi damper and flexplate will do the job
Powerhouse products
Probe Industries
