03-11-2006, 12:14 PM   #1 (permalink)
88gtconvt
Heads
I will be getting some heads for my 88 mustang gt here pretty soon and after reading up a bit on them I have been leaning more towards the twisted wedge heads from trickflow.You guys have any experiences with them?Good input? Any bad input? I am pretty new to the hobby,(or lifestyle rather haha) I was also planning on putting a cam in there too at the same time,(something with good rumble, yet still streetable) any recommendations? these will actually be my first mods to be done to the engine . The only things I have done so far to it are exhaust,4.10 gears(its an AOD) and a k&n filter.any info would be appreciated, thanks.
88gtconvt is offline   Reply With Quote
03-11-2006, 04:38 PM   #2 (permalink)
1 Bad 88 GT
Heads
The heads will help a bit but you won't see a big diff until you swap out the TB, MAF and intake. The biggest choke point on a stock 5.0 is the TB, MAf, then the intake and finally the heads.
03-11-2006, 05:53 PM   #3 (permalink)
ZephyrZ7
Heads
unless your car is california emission and is already a mass air car don't add the cam, at least not until you can convert it over to mass air. The speed density cars measure fuel requirements based on engine vacuum, the bigger cams rob that and the fuel is not metered properly. Use the money to address the throttle body as was mentioned already.
03-12-2006, 12:21 AM   #4 (permalink)
65Kustom500
Heads
TB... I know I would!!
65Kustom500 is offline   Reply With Quote
03-12-2006, 07:03 PM   #5 (permalink)
tonys10sec306
Heads
twisted wedge heads are good
03-13-2006, 09:21 PM   #6 (permalink)
whitefifty
Heads
Go with the tw heads they are a good choice I'm actualy saving up to buy those for my fox. I think your choice of first mods is good, they will give you more hp for your dollar, but you should consider the tb,and maf if your car has it,if not convert it.
whitefifty is offline   Reply With Quote
